NEED HELP BAD Truck won’t start after replacing starter, battery AND starter relay !!! NEED HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by B.rad31, Feb 17, 2020.
  1. Feb 17, 2020 at 5:40 PM
    B.rad31
    B.rad31 [OP] Member
    Brian
    2002 Toyota Tacoma 4x4 v6 (manual)
    I have a 2002 Tacoma 4x4 Manual
    My truck would give me problems in the past of not starting but nothing this long. I’m a USMC service member (2147) and my truck is back home (291miles away)so it’s really hard for me to make time to work on it. I need to get this thing up and running I’ve done the obvious I have cleaned out the terminals, a new battery , a new starter, a new starter relay and I’ve ran out of ideas to get this thing to crank over ! All the lights turn on just fine in my truck like the HUD and headlights but when I try to crank it I just hear a zap in the wire that connects to the starter with a nut......... any advice or help works
  2. Feb 17, 2020 at 5:46 PM
    ForestRunnerFrank99
    ForestRunnerFrank99 Well-Known Member
    Josh
    Rancho Cucamonga, CA
    '99 TRD 4x4 Manual 3.4l v6
    Fox Coil-overs, Dakar Leafs, Intake, Tires, Rims
    So the starter doesn't turn?
  3. Feb 17, 2020 at 5:47 PM
    B.rad31
    B.rad31 [OP] Member
    Brian
    Nope just hear a zap coming from it
  4. Feb 17, 2020 at 5:48 PM
    Bishop84
    Bishop84 Well-Known Member
    Could be a bad starter out of box.
    My next step with your truck would be to remove it and bench test it.
    Could be resistance due to poor grounding, burnt wire, weak new battery etc.. but bench testing a starter goes a long way.
    TnShooter and B.rad31[OP] like this.
  5. Feb 17, 2020 at 5:48 PM
    ForestRunnerFrank99
    Josh
    Do you have the terminals on the starter crossed? Is the clutch switch working properly? Will it start in neutral with the clutch cancel button?
    Also what @Bishop84 said
    B.rad31[OP] likes this.
  6. Feb 17, 2020 at 5:50 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Bad wire, replace it, they corrode inside the shielding.
  7. Feb 17, 2020 at 5:59 PM
    B.rad31
    B.rad31 [OP] Member
    Brian
    Thanks guys
    @Bishop84 I’ll try a bench test but how do I “bench test”? just touch the negative a positive terminals with a wire to the starter form the battery and just see if it rips ?
    @Black DOG Lila the wire that has the nut tightening the wire to the starter looks good and un corroded tho
  8. Feb 17, 2020 at 6:03 PM
    Bishop84
    use jumper cables from a battery, ground to the starter case, and the positive to the B terminal on the solenoid.
    Then use a wire from the B terminal to the S terminal to simulate the ignition.
    It should spin, and push out.
  9. Feb 17, 2020 at 6:10 PM
    B.rad31
    B.rad31 [OP] Member
    Brian
    Is there anywhere specific where I should look or just follow the wires all the way up until I make my way back to the battery ?
    @Bishop84 thanks man !
  10. Feb 17, 2020 at 6:11 PM
    B.rad31
    B.rad31 [OP] Member
    Brian
    Terminals on the starter crossed ? I don’t know how I would do that or know if I did that ? And everything works but the started ..... the starter just won’t work
  11. Feb 17, 2020 at 6:12 PM
    Taco Roofer
    Taco Roofer Well-Known Member
    Noah
    Southern Oregon
    2004 Tacoma 4dr 4x4
    The work beast and weekend warrior rig.
    Take a small hammer and tap the starter and solenoid. Try also a tap on what would be the end cap or face of the solenoid.
    I dealt with this for almost a year on my 4Runner... as luck would have when the original burnt out, the two new replacements were bad but bench tested good! Once I got to new starter #3 I finally got a good one and problem solved.
    Not sure how I get so lucky sometimes hahaha!
    Black DOG Lila likes this.
  12. Feb 17, 2020 at 6:22 PM
    B.rad31
    B.rad31 [OP] Member
    Brian
    Are you fucking kidding me man ? Hahahaha but I tried that I banged the shit out of the old one and the new one .... is there any way I can skip buying two other starters before getting it to work ?
    Taco Roofer[QUOTED] likes this.
  13. Feb 17, 2020 at 6:24 PM
    Taco Roofer
    Noah
    Southern Oregon
    2004 Tacoma 4dr 4x4
    Hahaha! I'm a lucky muthaf'er sometimes!
    Well, you tried that trick sooo... sorry man that's all i got.
  14. Feb 17, 2020 at 6:39 PM
    TacoTaco02
    TacoTaco02 Well-Known Member
    Illinois
    02 Ext Cab SR5 TRD 4x4 V6
    What kind of starter?
    Starters and alternators are notorious for being bad out of the box from parts stores.
    I'd stick with new for these parts and only use Denso, Bosch, or some other oem supplier.
  15. Feb 17, 2020 at 7:19 PM
    B.rad31
    B.rad31 [OP] Member
    Brian
    Tanks man
