Need Help bad.....(with pics)
Discussion in '1st Gen. Tacomas (1995-2004)' started by CobraGod, May 1, 2010.
  1. May 1, 2010 at 6:55 PM
    CobraGod
    CobraGod [OP] Active Member
    This is my friends 2003 3.4 4x4 4 door taco.
    About a month ago I installed the blower/fuel pump/LC-1 Wideband/boost gauge. It ran fine after all that and today I installed the URD tuner box thing. I ran all the wires right(because I rechecked them 4 or 5 times) then I started it and it ran fine with no check engine light or no problem.
    But after eating dinner I was going to drive it back to his house and now it won't start. I have the fuel line off the 7th injector and thats how I know no fuel is coming out after I turn the key or try to start it.
    So I checked spark and fuel. Well its getting spark but no fuel. Checked the fuses and the relay and still nothing.
    So any help, also do these trucks have a fuel pump reset button?
    Thanks for any help you guys can give me.
  2. May 1, 2010 at 10:16 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    The ECU will not turn on the fuel pump until it sees an RPM signal coming from the engine.
    The RPM signal will not pass through the URD PCU if it does not power up with the ECU.
    When you turn the key to the run position does the CHECK ENGINE light come on?
    If not you likely have a blown EFI fuse preventing the ECU from getting power.
    If it does come on, double check your wiring and I hope you did not use those splicing connectors because that will do it every time.
    Gadget
  3. May 1, 2010 at 11:09 PM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    wow all of us coulda guessed for ya all day. you get it straight from the Man!
  4. May 2, 2010 at 11:57 AM
    CobraGod
    I'm gald he came in here because I'm so lost.
  5. May 2, 2010 at 12:02 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Kenwood DDX-512 Deck, Boston Acoustics G5 Sub in Ported Bassworx Box, Kenwood eXcelon KAC-X10D Amp, Sirius Satellite Radio, Magellan GPS, DDM 55w bi-xenon headlights, 2 HID Hella 500ff's mounted behind grill, 4 pc ebay Billet grill, Fog Lights (my truck didnt have them stock), Pioneer Speakers 6x9's(front) 6.5's(rear) AFE Cold Air Intake, Hose Clamp Mod, Tailgate Strengthen Mod, Removed Gay Mud Flaps, De-Badged, BHLM, 245/45/20 on velocity wheels. VW865a, Extra D Rings In Box, OEM Cruise Added Optima Red Top Battery
    is there a way to check to see if the urd pcu powers up with the ecu?
  6. May 2, 2010 at 1:43 PM
    CobraGod
    Well I wired everything back to stock and still getting a check engine light and no fuel.
  7. May 2, 2010 at 1:52 PM
    CobraGod
    Here is what it looks like if it helps, also here is the wire diagram I got for it.
  8. May 2, 2010 at 1:59 PM
    Cars0n`
    Carson
    Edmonton AB
    would the fuse for the fuel pump be popped?
    or are the injectors plugged or dirty?
  9. May 2, 2010 at 2:16 PM
    CobraGod
    I just put a code reader on it and it got nothing.
    I checked the fuses and its not the injectors because I'm not getting fuel to the fuel rails. I can't hear the pump kick on like I could with any of my mustangs.
    I'll post pictures of the fuses I checked to see if you guys see something I over looked.
  10. May 2, 2010 at 2:22 PM
    Cars0n`
    Carson
    Edmonton AB
    hmm. well chances are, if you cant hear it kick on and there is no fuel getting to the rails, its a probably the pump. bad connection on the pump (+ and -)? maybe the pump just shit the bed?
  11. May 2, 2010 at 2:27 PM
    CobraGod
    Here are the ones I have checked.
    And for the people helping. HAHAHA
  12. May 2, 2010 at 3:54 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    just remember that our fuel pumps dont work like the mustangs...they only pump when we crank the engine. unlike the mustangs when the car is first given power.
  13. May 2, 2010 at 3:58 PM
    CobraGod
    Even when I crank on it I get nothing. Taking the fuel line off the 7th injector I should get fuel coming out of it when I crank on it.
  14. May 2, 2010 at 4:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Have you checked to see if your getting 12v to the pump when you crank it?
  15. May 2, 2010 at 4:04 PM
    CobraGod
    Yes I'm getting 12.xx volts to the pump.
  16. May 2, 2010 at 4:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And the pump isnt working...Me thinks the pump could be burned out...
  17. May 2, 2010 at 4:51 PM
    CobraGod
    Thats what I'm thinking too.
  18. May 2, 2010 at 6:10 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    is it possible to bypass the fuel pump and use a small gas tank and gravity feed the system just as a test to see if it is the problem?
  19. May 2, 2010 at 6:13 PM
    Gadget@URD
    Did you start it up after installing the pump and before you did anything else?
    Is there any chance you got the fuel lines crossed up when you reinstalled the tank?
    You can gets the URD PCU by connecting your PC to it. If you can get a connection it is powering up when you go key on.
    Your pictures seem like you don't have the PCU installed. Did you remove it? If so and you still have this no start problem it is not likely the problem. Focus on the pump.
    You can call URD Tech Support if you need help.
    G
  20. May 2, 2010 at 6:18 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    also make sure to have someone have their ear to the gas cap and when you turn the key to the ON position, you should hear the fuel pump whine a bit
    AND make sure to keep posting girlie pics so we stay interested ;)
