Need help!!! Ball joints
Discussion in 'New Members' started by EMT1994, Nov 28, 2018.
  1. Nov 28, 2018 at 10:14 AM
    EMT1994
    EMT1994 [OP] New Member
    Mason
    GA
    01 PreRunner SR5
    CB radio, black tool box, aftermarket radio,
    I have a 2001 Tacoma 2wd. It has a 3in leveling kit on the front and stock in the back. I keep replacing upper and lower ball joints. Is the leveling kit causing the problem. Or how do I fix the issue?
    Thanks
    irayfz6 likes this.
  2. Nov 29, 2018 at 5:47 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW! How often are the ball joints going out?
    Running Board Man and irayfz6 like this.
  3. Nov 29, 2018 at 6:27 AM
    EMT1994
    Mason
    GA
    01 PreRunner SR5
    I’ve replaced both side twice the past year
  4. Nov 29, 2018 at 6:58 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
  5. Nov 29, 2018 at 7:04 AM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    Without seeing your front end setup it's hard to say. I had the OEM upper ball joints for 170k and lower ball joints for 175k before replacing them.
    What is happening to the ball joints that requires you to replace them? are they snapping? Is there excessive wear from lack of lubrication?
    irayfz6 likes this.
  6. Nov 29, 2018 at 7:08 AM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    OP, if it looks like this, it's definitely caused by the spacer lift.
    I've also heard about ball joints shipping dry from the factory, but I don't think that is the issue here.
  7. Nov 29, 2018 at 7:17 AM
    EMT1994
    Mason
    GA
    01 PreRunner SR5
    I’ve had the uppers on both sides snap in half. I had 33s on the truck at the time and since I put a new front end under it and put smaller tires back on I haven’t had a problem except one lower that was not replaced for some reason when I got it fixed but, that’s being replaced. So I’m guessing taking the spacer off will solve everything?
  8. Nov 29, 2018 at 7:23 AM
    EMT1994
    Mason
    GA
    01 PreRunner SR5
    I was told that if I change the upper control arms it would fix it, but which ones do I get if that’s the case?
    Running Board Man likes this.
