Need help between deciding between two lifts!
Discussion in 'Suspension' started by NewToy05, Feb 12, 2013.
  1. Feb 12, 2013 at 4:23 PM
    NewToy05
    NewToy05 [OP] Member
    Tug
    Colorado
    05 Double Cab TRD
    I have a 2005 DCSB TRD OR 4x4 that I am planning on lifting in the near future. I am going to have approximately 120lbs of extra weight up front and have an ARE shell on the back. I would like to end up with between 2 and 2.5 inches of lift, but definitely don't want to exceed the 2.5in mark. The two lifts I am looking at are the OME Suspension Lift kit from Toytec with 885 springs and drivers side lean spacer or the Bilstein Adjustable Lift Kit with 5100 shocks. I would set the 5100's at .85 and use a drivers side lean spacer with this kit as well. 2in Toytec AAL would be used with both lifts for the rear.
    If it was your build, which would you put on your truck. Thanks for your help!!
    OME Suspension lift kit
    Bilstein Adjustable lift kit with 5100 shocks
  2. Feb 12, 2013 at 6:38 PM
    pivey14
    pivey14 I'm A Grinder
    Patrick
    Baton Rouge, LA
    '11 DC Base PreRunner
    See Build Thread
    I'm doing the Bilstein Adjustable lift kit with 5100 shocks because it is a couple $100 cheaper than the OME kit, yet it rides just about the same. I am also doing the 2" AAL which will give me a little rake which I want.
  3. Feb 21, 2013 at 7:09 PM
    Gus 524
    Gus 524 Well-Known Member
    Justin
    MN
    09 tacoma SR5 4WD 4-cylinder
    Doing the same thing just waiting for some $$. Keep me updated on your lift.
  4. Feb 22, 2013 at 7:50 AM
    NewToy05
    Tug
    Colorado
    05 Double Cab TRD
    I have decided to go with the OME lift with the 885 springs. I think that it will give me a better ride overall with the slighlty softer springs, and I will not be pre-loading them either.
  5. Feb 23, 2013 at 9:20 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Good choice, i love my setup and this is what i have
  6. Feb 23, 2013 at 11:33 AM
    Gus 524
    Justin
    MN
    Ok good for you man but now you got me worried about the ride I'm going to get will the bilstens. :(
  7. Feb 23, 2013 at 11:52 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    My 5100s ride nicer than stock. I think you'll be fine.
  8. Feb 26, 2013 at 8:40 AM
    Gus 524
    Justin
    MN
    Ok glad to hear that! Thanks
