Need help Big mud terrain
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 96fido96, Dec 1, 2016.
  1. Dec 1, 2016 at 5:05 PM
    96fido96
    96fido96 [OP] Well-Known Member
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    Ok so I bought Bfg mud terrain size 255 75r17 and I have a 10 inch wheels levels 8 4.5 bs can I use these 10" or should I get shorter width
  2. Dec 1, 2016 at 8:38 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I'd say mount one and put on the front to see if it fits, my tire guy calls it a fit & hit, I think you should fine, I run 285/70/17 4.5 bs on 17x9.
  3. Dec 1, 2016 at 8:48 PM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    They will be low pros stretched out close to popping beads. I wouldn't personally. They will need a cheetah to put that on the rim
    My 265 looked stretched out on a 9 inch wide rim. It will work but not suggested
  4. Dec 1, 2016 at 9:00 PM
    96fido96
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    Thanks guys
