Need help!! Blower has oder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDOFFROAD14, Jul 27, 2016.
  1. Jul 27, 2016 at 12:05 AM
    TRDOFFROAD14
    TRDOFFROAD14 [OP] Well-Known Member
    Manny
    Lanai city hawaii
    2023 tacoma 4x4 offroad
    I have a 2014 tacoma offroad and when i turn on a/c or fan on, its has oder, i alrdy clean the filter behind the glove box and still has smell, with alot of leaf and lent on it but did not wash or clean,, any thing i need to knw.. Any advice what else to do? Advice would be great .. Thankx
  2. Jul 27, 2016 at 12:11 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  3. Jul 27, 2016 at 12:25 AM
    Tom0662
    Tom0662 Well-Known Member
    Tom
    Iowa
    2016 TRDORSB
    It is too late for you now but what I always do and have never had issues is a
    little before I get to where I am going I turn off the ac and turn the fan on high to help
    dry out the evaporator.
    You will need to do something now like what Jimmyh has posted.
    shakerhood likes this.
  4. Jul 27, 2016 at 3:36 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    Check for a dead mouse in the blower... it can and does happen.
  5. Jul 27, 2016 at 3:41 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Just spray some Lysol or Febreeze in the fresh air intake
    Mush Mouse likes this.
  6. Jul 27, 2016 at 6:05 AM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    This is what I'd recommend too. There are Youtube videos showing you where/how to do it. I bought this AC system cleaner spray from a local auto store for like $7 and it did work, but I'll warn you that whatever the chemical is is harsh stuff. Good Lord, I was breathing it for a week and it was burning my lungs. I had to park with the windows open just to help clear it out. Nasty stuff. Next time I'm going the Lysol route.
  7. Jul 27, 2016 at 10:45 AM
    qwikz74
    qwikz74 Member
    Ontario,Canada
    2015 Tacoma TRD Sport 4x4 DCAB
    Check the drain hose,might be plugged and not allowing all the condensated water out.That smell is from a bit of water being left over from either a plugged drain or not running the A/C long enough (short trips) If you found allot of leaves and such im willing to bet the drain is plugged.
    Id rather smell that stale smell for a few miles over any chemicals.My Sierra was bad for that but it would clear up after 10-15mins or driving.
  8. Jul 27, 2016 at 11:47 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I do the same
    Tom0662[QUOTED] likes this.
  9. Jul 27, 2016 at 5:26 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    I'm betting this. Just had it happen on my 1998 Sonoma, started to smell, never had an issue with that, Drain was plugged, cleaned it out and back to cold non stinky air as usual.
  10. Jul 27, 2016 at 5:30 PM
    superorbital
    superorbital Well-Known Member
    2015 White TacoMama TRD
    Where is the drain? Mine is doing the same thing.
  11. Jul 27, 2016 at 5:31 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    Lysol worked for me, and new cabin filter
  12. Jul 27, 2016 at 5:33 PM
    Mush Mouse
    mush
    2013 SR5
  13. Jul 30, 2016 at 4:53 PM
    TRDOFFROAD14
    Manny
    Lanai city hawaii
    Thankx guys for the help and advice,, but can u guys tell me where to check if its plugged so i can drain it,,
  14. Jul 30, 2016 at 9:30 PM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    Look in here and see if you see any sort of nest or build up (Photo credit: @GREENBIRD56 )
    Lord Helmet likes this.
  15. Jul 30, 2016 at 9:37 PM
    shakerhood
    Southern Ohio
    You should see a small puddle of water under the passenger side when you park after using the AC, that should tell you its draining correctly.
  16. Jul 30, 2016 at 9:41 PM
    TRDOFFROAD14
    Manny
    Lanai city hawaii
    Thankx you all.,,
  17. Jul 31, 2016 at 8:10 AM
    Notoneiota
    Oakdale, MN
    I had a mouse build a nest in mine within the first 15k of owning it. I live in the city BTW. I discovered that I can stick my fingers up inside that cavity from the filter side. It funnels down so big debris like leaves and mouse nest can sit up in there and you can't tell. Now I check every oil change. Little bastard chewed all the foam that lines the walls inside the intake and some from the firewall in the engine bay. Must be soy based or something.
  18. Jul 31, 2016 at 8:54 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    When I changed my engine air filter a couple months ago I found bird seed in the intake box. Luckily nothing chewed. I dont know if it was a mouse or a chipmunk. I have a chipmunk that gets in my garage and steals bird seed. Hes also been wreaking havoc on my landsacaping. I set up a live trap to get him. The other day I noticed he set it off and was inside it. I was like, WOOT. Me - 1 : Chipmunk - 0. I went to pick up then trap and the chipmunk squeezed through the cage holes and ran under my deck. I dropped my head and walked away in defeat.
    Lord Helmet and HawkShot99 like this.
  19. Jul 31, 2016 at 9:19 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    :laugh:
  20. Jul 31, 2016 at 9:44 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Lol, when I read the title , my first thought was " stop picking up working girls from that street then, and try another location"
