Need Help: Bought some custom fabbed UCA's
Discussion in 'Suspension' started by RacerP, Dec 24, 2011.
  1. Dec 24, 2011 at 4:44 AM
    RacerP
    RacerP [OP] Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    So, I finally got around to having some used ICON's I bought off of Craigslist rebuilt and installed them. Got an alignment and not even close.
    I recently found these UCA's which I think I got a screaming deal on? $225+shipping. When looking for used and abused TotalChaos or Camburg UCA's most got for around $350 and need rebuilding as well.
    So I have a couple of questions on what I need to build these out? I have absolutely zero experience with aftermarket UCA's and have been trying to research rebuilding them and come up with nothing? Scheduled to have my frame replaced by the stealership in a couple of weeks and want to have these ready to go when that happens...hell, free labor is free labor.
    Obviously, to start with, going to have them powder coated.
    Parts? Cups, and uniballs are readily available on DezertRangers or race-dezert. So are misalignment spacers...but what am I looking for? 5/8" spacers? And, also 5/8" spindle adapters?
    I don't think these are drilled for zerks? Do you really need zerks? Can I drill my own holes and buy self tapping ones from the big box auto parts store?
    Figured I an measure out the pivot points and order bushings and sleeves from Energy Suspension?
    And, as far as bolts, washers and lock nuts...can't I just pick up the appropriate sizes in hardened grade 8 or 10 from my local hardware store?
    Am I on the right track? Is there a write-up somewhere that I am missing or haven't found?
    I know, lots of questions, sorry 'bout that. But, appreciate any input.
  2. Dec 24, 2011 at 5:08 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
  3. Dec 24, 2011 at 5:10 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    First off, what was wrong with your alignment with the icons. If they are made for your truck you should have been good. Did you install them correctly??
  4. Dec 24, 2011 at 6:47 AM
    RacerP
    Chicago
    2003 4x4
    Yeah I do have them installed correctly, ALTHOUGH, I did bend the lower mount tabs on the LCA's slightly when trying to get the old shocks bolts out? Ended up having to cut the old shocks out at the lower mounting points. Did my best to straighten the tabs back.
    Got the ICONS's cranked up to about 2.5" of lift.
    After getting the alignment done on a Hunter machine, they got the camber and toe to very close to 0 but, they could only get the caster to about .4?
  5. Dec 24, 2011 at 7:16 AM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    It won't be perfect. I'm not sure what the limits are for the alignment. But long as it's within spec.
  6. Dec 24, 2011 at 7:19 AM
    RacerP
    Chicago
    2003 4x4
    Caster is supposed to be closer to 2.5 and researching here, the aftermarket UCA's will get it there.
  7. Dec 25, 2011 at 10:24 AM
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    Hope that helps, good luck
  8. Dec 25, 2011 at 11:52 AM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Hey those are the Race Dezert arms. You need probably two 1' uniballs. Four misalignment spacers. two clips. Slug Adaptor for the spindle. Complete Bushing kit. Grade 8 bolt 3/4" bolt i belive it is. Do they need Zirks sure, put them on. Or just make sure they are greased.
  9. Dec 26, 2011 at 7:07 AM
    RacerP
    Chicago
    2003 4x4
    Sure does help. Thank you. I am assuming that the lips can be powdered, and the insides all have to be taped? Now to decide what color???
    Yes they are from Race-Dezert, Solo Motorsports built them. I figured they were a pretty good deal. My only question is that so many of the misalignment spacers look different from the ones available from TotalChaos or Camburg, are there any that are wrong?
    http://www.dezertrangers.com/vb/parts-accessories/147076.htm
    That's an old post on DezertRangers, and already sold, but, I believe, exactly what I am looking for?
    And a pic of 8 misalignment spacers available, 5/8"-3/4", would need those too? But, only 4?
    Again guys thanks for your input.
  10. Dec 26, 2011 at 12:23 PM
    Anthony250
    Anthony
    Rialto CA
  11. Dec 26, 2011 at 2:45 PM
    RacerP
    Chicago
    2003 4x4
    Hey thanks Anthony, saw that FK setup on eBay earlier...
    You MUST be the same Anthony250 looking for used 1" uniballs on DezertRanger???
    I am figuring that I can purchase all the stuff on the eBay ad separately from the forums alot cheaper!
    Peter
  12. Dec 26, 2011 at 3:18 PM
    Anthony250
    Anthony
    Rialto CA
    Yup thats me, but they were for my friend already found some.
