Need help. Brake light not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CJ27, Jul 15, 2020.
  1. Jul 15, 2020 at 10:29 AM
    CJ27
    CJ27 [OP] Member
    This is a strange one. The brake lights work fine unless I have the cruise control on. Then they don't work and the cruise light flashes after pressing the brake pedal.
  2. Jul 15, 2020 at 10:42 AM
    Cb Colorado
    Cb Colorado Active Member
    Black 2008 Tacoma SR5
    OME 885 Bilstein 5100 front and rear RCI Rock Sliders 285/70/17 BFG KO2
    Well seeing how pressing the brake suspends the cruise control seems like working as intended, with the flashing cruise control light. Does it resume fine? Did someone tell you that your brake lights dont work when you are in cruise because that would be difficult to find out.
    Also I dont have cruise control so I cant really say if thats how that actually works in a 2nd gen
    SR-71A likes this.
  3. Jul 15, 2020 at 10:49 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    What year model is your truck? And how do you know the brake lights dont work, have someone following you?
  4. Jul 15, 2020 at 10:53 AM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    Brake lights or Tail lights?
  5. Jul 15, 2020 at 10:56 AM
    CJ27
    CJ27 [OP] Member
    Sorry it's a 2007, and it's the brake lights the tail lights work. To use cruise control again I ha e to turn it off and back on to stop the flashing. And I had my wife press the brake pedal and stood behind and watched. Had her turn off cruise control and the brake lights work... so strange
  6. Jul 15, 2020 at 11:08 AM
    SR-71A
    Zack
    Southern Maine
    Dont think Ive ever seen the cruise control light flash. Push the cruise control stalk to arm the system and turn the light on, push again to turn off in my 2012. Maybe these trucks have a lower speed limit under which the system doesnt work (and flashes the light..)?
  7. Jul 15, 2020 at 4:03 PM
    CJ27
    CJ27 [OP] Member
    It is doing this at any speed.
  8. Jul 15, 2020 at 4:18 PM
    CJ27
    CJ27 [OP] Member
    Ok so googling the issue someone said to cycle the emergency flashers on and off a few times and see if that helps that the circuit runs though there. Figured easy enough to try it and now its working like nothing is wrong at all. Idk if it's a fluke but it was doing it everytime the cruise control was on and now working as intended.?
  9. Jul 15, 2020 at 4:28 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Maybe it’s telling you that cruise control doesn’t do anything when you are parked.
  10. Jul 15, 2020 at 4:38 PM
    CJ27
    CJ27 [OP] Member
    The issue happens when driving. I took it down the road everything working as intended after turning the flashers on and off a few times.... goofy
  11. Jul 15, 2020 at 4:41 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Sounds like a brake light switch that might be on the verge of failing. Do you ever have a hard time getting it out of park when depressing the brake pedal?
    TnShooter likes this.
  12. Jul 15, 2020 at 4:48 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I agree, there is probably an issue somewhere other than the CC.
    Do you have a check engine light?
    If a malfunction occurs in the vehicle speed sensor,
    stop light switch assembly or other related parts
    while cruise control driving, the ECM actuates
    AUTO CANCEL of the cruise control. Then the
    CRUISE MAIN indicator light starts to blink, to
    inform the driver of the malfunction. At the same
    time, data of the malfunction is stored as a
    diagnostic trouble code (DTC).
  13. Jul 15, 2020 at 5:06 PM
    CJ27
    CJ27 [OP] Member
    No DTCs. It's a 6 speed manual so no issues with getting out of park. And tapping the brake pedal will always cancel the cruise.
    SR-71A likes this.
  14. Jul 15, 2020 at 9:06 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Maybe it is an issue with the clutch Switch...
  15. Jul 17, 2020 at 1:12 PM
    CJ27
    CJ27 [OP] Member
    Don't think so the clutch switch seems to work fine.
  16. Oct 23, 2020 at 11:45 AM
    CJ27
    CJ27 [OP] Member
    Ended up being a bad brake light switch. Very easy to replace. Thanks for all y'alls help.
    Muddinfun and TnShooter like this.
  17. Oct 23, 2020 at 11:50 AM
    TnShooter
    Deogee
    STOCK
    Thanks for the update
    Good to see you got it fixed.
