Need Help, Bump Steer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lee_533, Nov 20, 2016.
  1. Nov 20, 2016 at 9:16 AM
    Lee_533
    Lee_533 [OP] Well-Known Member
    Andrew
    2016 Tacoma SR5 4X4
    2.5" Extended Travel King Coilovers, Camburg Uniball UCAs, Total Chaos LCAs, Dakar Leafs, Fox Rear Shocks, warn winch, Full Relentless armor, arb on board air compressor, 35” Tires
    Hey guys, I need some help tracking this bump steer down. Here's the story. When I lifted my truck I lifted the front first and got an alignment because I wasn't sure if I would have time to lift the rear before my trip. 3" lift up front with 185/75r16 Duratracs all around. When I drove it home from the alignment it felt great, no steering issues at all. The next day I had time to install my rear Dakar leaf packs (third leaf removed). After lifting the rear I had bump steer. I figured it was the caster so back to the alignment shop. I had them set 3.5 positive caster (from what I've read on here that's what most people recommend) and align everything else. Still have bump steer. Not terrible but I can feel it driving on pavement over small stuff. The wheel always re-centers itself but I can't figure out why I have it. So my question, why did I only get bump steer when I lifted the rear?
    Vehicle specs:
    2016 SR5
    Bilstein 5100 with OME 888s
    Dakar leaf pack
    Light Racing UCAs
    285/75 r16 Duratracs set at 35 psi.
    ChadsPride likes this.
  2. Nov 20, 2016 at 9:23 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Hood skewp?
    ChadsPride, jmaack and PROseur like this.
  3. Nov 20, 2016 at 9:58 AM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    What?
    ChadsPride and dYL0n like this.
  4. Nov 20, 2016 at 12:15 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    We put additional caster on our lifted-larger wheeled trucks to correct/improve the relationship between SAI and the tire.
    When you lift the rear, you change this relationship; more so when you deviate from factory rake.
    Caster as it relates to bump steer, usually means you have too much. Weight transfer to the front probably didn't help any either.
  5. Nov 20, 2016 at 12:34 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    So you're saying I have too much positive caster? Before I had 2.3 after the rear was lifted and now that I have 3.5 it seems like it has less bump steer but it's still there. So if I were to lower the front about .5" it might help correct the rest of the bump steer?
  6. Nov 20, 2016 at 3:05 PM
    splitbolt
    NW Arkansas
    Hmmmm....
    Would you mind describing what you think is bump steer?
    Aftermarket wheels? Specs?
  7. Nov 20, 2016 at 3:17 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    Bump steer as in my one of my front tires hitting a quarter on the road and it turns my steering wheel a little lol. It always recenters but the steering wheel still pulls to one side then centers going over bumps that you wouldn't even feel in any other truck. Wheels are procomp 8" with 4.5" back spacing to make it center. Tires 285/75/r16 Duratracs at 35 psi. Someone with a 2nd gen said that he had bump steer with the duratracs until he aired down to 35 from 42. Should I try running 30 psi and see what happens?
  8. Nov 20, 2016 at 3:30 PM
    splitbolt
    NW Arkansas
    I think you're on to something...
    Bigger tires don't require as much psi to attain their load rating.
    The converted tire placard pressure for your new tire type and size, is 30 psi.
    You're ideal pressure might be even lower.
    You might want to do a chalk test.
  9. Nov 20, 2016 at 4:06 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    shhhh.... there are a few members who think all E tires needs 60psi+ and other tires need 40+
    splitbolt[QUOTED] likes this.
  10. Nov 20, 2016 at 5:56 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    Well I dropped it to 30 and still have it. I think it's the fact that I still have camber. The alignment shop wouldn't give me 0 camber even though most guys are running it with lifts. Hopefully I can find someone that will set my alignment the way I want and see if that helps
  11. Nov 20, 2016 at 6:01 PM
    Aussiek2000
    2016 Offroad AC
    What did they set camber at?
    Do you have those bilsteins preloaded at all?
  12. Nov 20, 2016 at 6:04 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    The bilstein 5100s are on the 1 setting. If I remember right they set camber at 1.9 degrees
  13. Nov 20, 2016 at 6:06 PM
    Aussiek2000
    2016 Offroad AC
    That's a lot of camber. Bilsteins need to be on the lowest setting with 888's
  14. Nov 20, 2016 at 6:08 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    Well with the 6112s on the 0 setting it is about the same as the 5100s on the 1 setting. And yes, you can see the camber on it, top of the tires are out more than the bottom
  15. Nov 20, 2016 at 6:09 PM
    Aussiek2000
    2016 Offroad AC
    Problem I think is, you are making an already stiff spring even stiffer. Basically getting a pogo effect when you hit bumps.
  16. Nov 20, 2016 at 6:12 PM
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    ‘25 MT6 Off-Road
    Umm.. Thats generally not good.
    Lee_533[QUOTED][OP] likes this.
  17. Nov 20, 2016 at 6:12 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    Well I had the bump steer on the 6112s at the 0 setting. I swapped to 5100s because I had one of the 6112s go out
  18. Nov 20, 2016 at 6:13 PM
    Aussiek2000
    2016 Offroad AC
    Stock Tacoma's have positive camber. Look next time you pass one. Looks ignorant and handles like crap. I set mine to -0.4
  19. Nov 20, 2016 at 6:13 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    Exactly, I think that's why I have the bump steer.
  20. Nov 20, 2016 at 6:13 PM
    Aussiek2000
    2016 Offroad AC
    Just giving my opinion. Take it for what it's worth.
