Need Help, Bump Steer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lee_533, Nov 20, 2016.
  1. Nov 20, 2016 at 6:15 PM
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    ‘25 MT6 Off-Road
    I agree, I don't think it is helping you at all.
    Aussiek2000 likes this.
  2. Nov 20, 2016 at 6:16 PM
    Lee_533
    Lee_533 [OP] Well-Known Member
    Andrew
    2016 Tacoma SR5 4X4
    2.5" Extended Travel King Coilovers, Camburg Uniball UCAs, Total Chaos LCAs, Dakar Leafs, Fox Rear Shocks, warn winch, Full Relentless armor, arb on board air compressor, 35” Tires
    I know what you mean. The ome springs are stiff. I'm just saying that the bump steer has been an issue since I had the springs set at the lowest mark. I'll have a steel bumper on soon so maybe that will help
  3. Nov 20, 2016 at 6:17 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Same height setting on both shocks, bump steer on both shocks. See what I'm getting at.
  4. Nov 20, 2016 at 6:23 PM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    I've always thought bump steer came from abnormal camber, while caster causes lightness or heaviness in steering/handling.
  5. Nov 20, 2016 at 6:44 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    No the 6112s were on the lowest setting possible. I might try the 5100s on the lowest but that will drop my front about an inch from where it is now.
  6. Nov 20, 2016 at 6:46 PM
    swordfish
    Jon
    CT
    ‘25 MT6 Off-Road
    Bump-steer is typically caused by changes in toe as the suspension compresses. As the suspension compresses the relation of the control arms to the knuckles causes undesired movement.
    What you are talking about is the traditional bump steer behavior is exacerbated by the camber issue.
    bradwhitenikki likes this.
  7. Nov 20, 2016 at 6:48 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    So it is definitely from having 1.9 positive camber? I've tried to tell the shop I didn't want any camber
  8. Nov 20, 2016 at 6:52 PM
    swordfish
    Jon
    CT
    ‘25 MT6 Off-Road
    I couldn't say for sure without seeing the rest of the alignment specs, but I imagine it is not helping any.
  9. Nov 20, 2016 at 6:54 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    Caster is 3.5 camber and toe are both set at 1.9 I believe.
  10. Nov 20, 2016 at 7:02 PM
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    You normally have to adjust the outer tie rod end height, with respect to the spindle mount, to correct bump steer problems. Raising or lower a vehicle always presents this problem. Most people selling these kits leave this part out. Not good for sales.
  11. Nov 20, 2016 at 7:06 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    The only way that I know of leveling the tie rods out would be a diff drop but that eliminates the point of the lift in my opinion and I wouldn't be able to run skids
  12. Nov 20, 2016 at 7:07 PM
    bradwhitenikki
    Brad
    I have never seen where static positive caster is a good thing.
  13. Nov 20, 2016 at 7:09 PM
    swordfish
    Jon
    CT
    ‘25 MT6 Off-Road
    If you have 1.9° Camber and 1.9° Toe your alignment is a mess.
    You should be running a minor negative camber and a minor toe in or 0 toe.
  14. Nov 20, 2016 at 7:12 PM
    bradwhitenikki
    Brad
    Leveling the tie rods isn't the answer, though many say this. The real answer is keeping the arcs of the control arms, and the tie rods, working together. Really, a bumpsteer gauge is usually needed. I normally set for just a smidgen of toe out on bump, with a midget of static toe in. Every case is different. I don't think you need to drop your diff.
  15. Nov 20, 2016 at 7:16 PM
    #35
    swordfish
    Jon
    CT
    ‘25 MT6 Off-Road
    Agreed, leveling is only required if you are getting binding on the joints.
  16. Nov 20, 2016 at 7:24 PM
    #36
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    Got it. Thanks guys. I'll take it to another alignment shop and see if they can fix it.
  17. Nov 20, 2016 at 7:25 PM
    #37
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    The info in this thread has been pretty wicked.
  18. Nov 21, 2016 at 3:39 AM
    #38
    Aussiek2000
    2016 Offroad AC
    Well I never said anything about caster so not sure why you quoted me
  19. Nov 21, 2016 at 3:53 PM
    #39
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Can you explain this a little more in depth please?
    I leveled my SR with the following:
    Front- TRD OR Take off Coils and shocks, toytec 1/4" spacer
    Rear- TRD OR Take off shocks and the stock SR leafs, no spacers.
    This setup gained me roughly 1.5" up front and a very small bump in the rear, about 1/4". Tire diameter is still stock.
    I noticed some bump steer so I got it aligned, turned out I had some toe-out. Bump steer went way down after alignment but I can still feel it a bit.
    My caster is at 1.6 and 1.7 degrees L/R, and SAI is 11.2 and 11.3 degrees L/R which is on the low end of spec. So, since I lifted I would need to lower SAI while adding caster?
    I feel like I'm missing the last puzzle piece here.
  20. Nov 22, 2016 at 4:00 AM
    #40
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    Well, still have it. 0 toe, 0 camber one side, and .3 on the other. My tires still look like they have camber but it could just be me. Maybe it's just because the suspension is still new and pretty stiff?
