Need help buying a new water pump and thermostat
Discussion in '1st Gen. Tacomas (1995-2004)' started by kevinl34, Sep 18, 2012.
  1. Sep 18, 2012 at 7:36 PM
    kevinl34
    kevinl34 [OP] Well-Known Member
    duncan s.c.
    toyota tacoma dbl cab sr5
    Greeting Im needing to change my water pump and thermostat I was going to go to advance auto in my area and pick one out but before I do that Im wanting you guys to chime in on the best to buy aftermarket or OEM thanks..
  2. Sep 18, 2012 at 7:47 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I always go OEM if the price is competitive. Check RockAuto.com. Water pumps are not high-tech. For these parts you should be good with whatever you can find.
  3. Sep 18, 2012 at 8:09 PM
    kevinl34
    duncan s.c.
    do you know the oem name brand of the water pump and thermostat?
  4. Sep 19, 2012 at 3:56 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Most likely Aisin, but I could be wrong. Not sure what engine you have, but RockAuto carries the Aisin water pump for both the 3.4L and 2.7L, both about $55.
    For the thermostat, just get a Stant or Gates OE Exact.
    Don't forget gaskets/seals.
  5. Oct 4, 2012 at 2:51 PM
    euro911s
    euro911s 'Plays with Toys'
    Mark
    So Bay, So Cal
    96 Tacoma 4x4, V6, Ex Cab
    I used to have a a TRD supercharger on the Tacoma, converted back to NA when I bought the Tundra. The SC was tons of FUN!!!
    Getting ready to replace my original timing belt on my '96 Tacoma, Ex Cab, V6, 4x4. Planning to replace the water pump, thermostat and o-ring 'while I'm in there'. I will also be replacing the all the accessory belts.
    I'm an air-cooled type of guy, and I have replaced water pumps on Chevy and Dodge V8 engines in the past, but the Tacoma pump is new territory for me.
    The Aisin part number I have been using to search on is W0133-1741932, available from several vendors.
    Rock Auto appears to have a better price for an Aisin pump, but they list the pump as part # WPT100. Are these the two different numbers same identical part?
    WPT100 indicates it includes a Gasket, and an O-Ring. Is there an additional gasket I need for the thermostat housing/water outlet? (The gasket I'm referring to is not an O-ring, it has a large opening in the center and three stud holes).
    Some vendors list the gasket some don't ... just want to make sure I order everything I'll need.
    I just replaced the front struts. What a difference! The lower mount bushings were shot :eek:
  6. Oct 4, 2012 at 4:14 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    RockAuto has a timing belt kit that also comes with the water pump, gaskets and hydraulic tensioner for 204.79 along with everything else you would need. It most likely comes with the gaskets, but I would add a thermostat, thermostat o-ring and extra thermostat housing gasket to the order to be safe -- the o-ring and gasket are only about a buck each -- doing an extra order and paying shipping would cost you more, better safe than sorry.
