Need help!! Can't shift.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Databox, Jun 19, 2014.
  1. Jun 19, 2014 at 10:52 AM
    Databox
    Databox [OP] Well-Known Member
    Fernandina Beach, FL
    2007 TRD Sport SR5
    Rims and Tires
    Looking for some guidance.
    I wired in some LED back up lights on my new rear bumper. I wired them into the taillight reverse light power...lights work fine.
    When I went to pull the truck out of the garage, it wouldn't shift out of park into drive, and there is an airbag warning light on the dash...
    what have I done???
  2. Jun 19, 2014 at 10:56 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    Try using the Transmission lock override button. Cant tell you exactly where it is, but its there.
    You probably blew a brake light fuse so the tranny doesnt know your pressing the brakes, thus not letting the shifter move..
  3. Jun 19, 2014 at 11:00 AM
    Databox
    2007 TRD Sport SR5
    Rims and Tires
    Thanks...I'll give it a try
  4. Jun 19, 2014 at 11:01 AM
    TwoTacos
    TwoTacos Well-Known Member
    Winnipeg, MB.
    2011 TRD DCLB Sport
    3" Leveling Kit with AAL, 5160/6112 Billsteins, LED Bed and under hood Lighting, backflip F1 tonneau cover, TRS HID Headlights, Homemade Satoshi Grill, heated seats, cluster and dash white LEDS, TPMS disable switch, ABS/VSC disable switch, fog light anytime mod, Backup Camera On anytime mod, Power locking tailgate, blue LED floor lighting c/w dimmer, tinted windows, aftermarket Nav/Audio with built in sub, aftermarket homelink.
    Check the IGN1 and IGN2 fuses located under the drivers side little compartment. I've seen it before.
  5. Jun 19, 2014 at 11:03 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Wow, maybe wrong wire ??...:confused:
    Hmmm, never heard of that button & don't think blowing a brakelight fuse is going to cause that, but with electrical ya never know where its going to lead..
  6. Jun 19, 2014 at 11:03 AM
    abunch
    abunch Well-Known Member
    Andrew
    Brooklyn
    04 Double Cab TRD
    icons, ucas, Deaver pack, DD, ARB, Warn 9k, 255-85 km2, rigid lights, yada, yada
    you blew your tail fuse. under dash or under hood. takes 3 second to fix once you find it.
    its safety mechanism. if you blow the fuse running brake lights the car locks the transmission so you are not driving around without brake lights.
  7. Jun 19, 2014 at 11:04 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    No shit huh ??..learn something new I didn't want to know about everyday....:)
  8. Jun 19, 2014 at 11:05 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Wow, that's a cool feature. More cars should have that.
    OP, hope this does it for you.
  9. Jun 19, 2014 at 11:23 AM
    Databox
    2007 TRD Sport SR5
    Rims and Tires
    OK....so I checked it and yes....IGN1 fuse was blown.
    Replaced the fuse, started up, airbag sensor off...truck shifts...then IGN1 fuse blew again.
  10. Jun 19, 2014 at 11:26 AM
    Databox
    2007 TRD Sport SR5
    Rims and Tires
  11. Jun 19, 2014 at 11:27 AM
    BamaToy1997
    Bill
    Navarre, FL
    Actually what happens is what the other guy said. you can't shift out of park unless your foot is on the brake. If the fuse is blown, than the shifter thinks your foot is not on the brake, thus you can't shift out of park. It is not a special safety feature.
  12. Jun 19, 2014 at 11:29 AM
    BamaToy1997
    Bill
    Navarre, FL
    two of those draw too much from the reverse light circuit. You should use a relay operated by the reverse light to control them.
  13. Jun 19, 2014 at 11:41 AM
    ranger098
    Brian
    Minnesota
    Those lights (although LED) myust draw a lotta power. Reverse lights wouldnt normally be used to splice other lights off of, so yes i think a relay would help you out in this situation. Get power from the battery or somewhere other than the reverse light. Sorry that probably isnt what you want to hear, more work! You should upload a pic of your bumper and new lights tho.
  14. Jun 19, 2014 at 11:48 AM
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
    Fuse under the dash.
    You probably lost your turn signals and A/C.
    There is a button under the little square cap on the shifter panel. That overrides the lockout
  15. Jun 19, 2014 at 11:51 AM
    abunch
    Andrew
    Brooklyn
    04 Double Cab TRD
    what if it was actually both what he said and what i said…..
  16. Jun 19, 2014 at 12:08 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    LOL.
    Based on the light specs, those things pull 3 amps -- IF the specs are accurate. I would allow at least 5 amps for steady run, but use a 10 or 15 amp in-line fuse (and run it from the battery, just using a relay off the reverse lights).
  17. Jun 19, 2014 at 12:11 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    you cannot really tap reverse bulb power for anything, they are so feeble.
    as others said, you need a real new circuit, and a relay for those monsters you show
  18. Jun 19, 2014 at 12:12 PM
    Aw9d
    Aw9d That one guy
    Really? that is the dumbest f-ing idea I've heard in a long time.....
    So you blow the fuse by accident for whatever reason and you can't even drive yourself to the store to buy new fuses? Wow.
  19. Jun 19, 2014 at 12:29 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    had this happen to me. i think its a 10 amp fuse to start? (correct me if im wrong) I wired in 2 - 55w back up lights to the reverse lights. then it occured to me... 55x2= 110w.. 110w/12V= 9+ amps alone. figure in the reverse lights themselves and your over 10amp. not the correct way to fix it but i just replaced with one fuse size bigger and haven't had a problem yet. plus in an emergency it gets you home.
  20. Jun 19, 2014 at 12:42 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    sum ting wong
