Need help choosing tire size
Discussion in 'New Members' started by Truckdogipa2, Aug 19, 2020.
  1. Aug 19, 2020 at 8:54 AM
    Truckdogipa2
    Truckdogipa2 [OP] Well-Known Member
    Mark
    2011 Tacoma trd sport long bed
    New frame, Upper control arms, roof rack , method wheels fallen tires duel battery
    So I do want a smooth ride over a looks. Should I choose for bf Goodrich 275/70/r17 with e load. A 275/65;/r17 in the e load. Or the 265/70/r17 in a c load? I am thinking the c load would be the most comfortable ride and will do everything I need on and off road. Will not be doing any rock crawling please advise
    I drive a 2011 TRD Sport which is the double cab long bed. For suspension I have the rxt leaf springs at option 2. I also am running Bilstein 6112 with the cir clip on the 4th notch and the 5160 in the rear. I have the jba high caster upper control arms with the factory lower control arm.
    My concern is running e load tire on light truck and although I won't feel much difference possibly running e load tire makes me feel uneasy how much it might cause issues for rest of my vehicle/ drive train please advise for longevity of vehicle rather then looks
  2. Aug 19, 2020 at 8:56 AM
    su.b.rat
    su.b.rat broken truck
    stick with C's, E's sound too hard for you.
    Shellshock and Black DOG Lila like this.
  3. Aug 19, 2020 at 8:58 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
    buckhuntin-tacoma likes this.
  4. Aug 19, 2020 at 8:58 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    sl load my guy.
    3JOH22A likes this.
  5. Aug 19, 2020 at 9:03 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Are you on OEM SL (P-metric) tires right now? If so, C load will feel harsh, E load even more so.
  6. Aug 19, 2020 at 9:19 AM
    Truckdogipa2
    Mark
    Thank you for your responses and welcoming me into the tacoma world
  7. Aug 19, 2020 at 10:40 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    You had the truck for several years and don't know what tires you have on there? :confused: What's the brand and model? TRD Sport usually came from the factory with P265/65-17 Michelin highway tires in SL. 275/65-17 would be nominally a 2% diameter increase, not noticeable for the truck.
    Due to the stiffer sidewall, load range C gives a noticeably harsher ride. You'll feel all the pavement cracks, expansion joints, and manhole covers a lot more. Load range D and E even more so. (Imagine having a tire solidly filled with rubber.)
    What BFGoodrich tire model are you eyeing? KO2? KM3? HT? Rugged Trail (aka Rugged Fail)?
  8. Aug 19, 2020 at 11:06 AM
    Truckdogipa2
    Mark
    So looking at the k02 to purchase from Costco. And no I have not had my truck. The same week I purchased I brought to Toyota and the issued me a frame recall so it has been w the dealership and I have been driving a lender 3rd edition
  9. Aug 19, 2020 at 11:12 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    I would advise driving for a few weeks after you get the truck back before making any changes. The truck is basically taken apart and put back together by Bob the flat-rate mechanic. All it takes is one pinched wire or bent connector pin to drive you mad with never-ending electrical gremlins. 80% of the time it'll be fine, though.
  10. Aug 19, 2020 at 11:26 AM
    coopcooper
    alberta canada
    take pictures off all your suspension mods, they threw my buddies dakars out and put in the tsb leaf pack when he had his frame done.
  11. Aug 19, 2020 at 12:41 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  12. Aug 19, 2020 at 1:10 PM
    Truckdogipa2
    Mark
    thanks . So still wondering if anyones run the 275s after a 2 in lift and how they have liked or disliked the ride.
  13. Aug 22, 2020 at 5:32 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  14. Aug 22, 2020 at 8:23 AM
    Truckdogipa2
    Mark
    I really would be pissed if they threw any of the parts out that I gave to them to install
  15. Aug 22, 2020 at 8:23 AM
    Truckdogipa2
    Mark
    I really do not think they would have the attority to do that .
  16. Aug 23, 2020 at 7:17 AM
    Truckdogipa2
    Mark
    1. Im thinking about the 265.70 r17 from Costco for the ko2 in a load c tire . I think for my setup that will look and serve me well. Second choice are the wild peaks A/T3W. Thanks again for responses and for welcoming me.
  17. Aug 23, 2020 at 7:18 AM
    Truckdogipa2
    Mark
    I def will not be wheeling in any e load tires
  18. Aug 23, 2020 at 7:31 AM
    Truckdogipa2
    Mark
    Heard back from Toyota. While doing the frame recall they are installing all my parts for 675. - includes; leaf springs by icon, jba high caster upper control, m arms, icon lower control arm skids, sway bar relocation by icon, toytec front differential drop kit , old man emu driveshaft carrier bearing and considering getting a new drive shaft as truck is at 110k . No idea yet on driveshaft. More information; icon rxt are set option 2 at 2.25 raise or 1.75 w 200 pounds load and running Bilstein 6112 in front again on 4th circlip which for the 05 and up tacoma is 2.15". So I am thinking that should be level w a trailer on the back. Any suggestions please advise. Again I haven't even driven this vehicle. I purchased it from a small dealer next town over from me for 17500, purchased it wo even test driving it . (Only did that bc my uncle highly suggested the guy who works on the vehicles himself and stands by the vehicles )and was lucky to have a appointment the next day at the Toyota dealership. Fingers crossed I got a call saying I was getting a new frame so here we are.
  19. Aug 23, 2020 at 7:34 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Welcome aboard
    C load all the way
  20. Sep 7, 2020 at 8:06 AM
    Truckdogipa2
    Mark
    So I ended up purchasing the method 703 during Labor Day say and purchased the 275/70r17 wild peak at3w in load c tires even though I understand they are 57.1 pounds . However with that being said think it will be softer ride then bf Goodrich k02. I believe I overpaid for tires at 930 with balance though but whatever
