(NEED HELP) Clicking noise from rear end
Discussion in '3rd Gen. Tacomas (2016-2023)' started by black3rdgen, Mar 24, 2024.
  1. Mar 24, 2024 at 9:16 AM
    black3rdgen
    black3rdgen [OP] Well-Known Member
    STL
    3G on 35s, 5.29s
    YW E30 tune, 5.29s, equal length dual exhaust, 2000w audio system
  2. Mar 24, 2024 at 9:18 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Says video is private
  3. Mar 24, 2024 at 9:22 AM
    black3rdgen
    STL
    3G on 35s, 5.29s
    Fixed.
  4. Mar 24, 2024 at 9:25 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    This just started after 170 miles of no noise on the new diffs? It sounds like it’s wheel speed related and not driveshaft speed related. Odd noise for sure though and can’t think of something specific. Have you tried running it with the wheels in the air?
  5. Mar 24, 2024 at 9:40 AM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    I hear a lot of what sounds like tire noise. New tires?
    I can hear the clicking / popping noise. Do you feel any jerking or slipping when the noise happens? ( thinking maybe ring and pinion related )
    Any difference between light acceleration and full throttle?
    Any noise while cruising steady speed? Noise during steady turn at an intersection? ( looking for anything that would relate solely to the Truetrac )
    Did shop refill the diff oil?
    Thinking either something has come loose, Truetrac not happy, or foreign object in axle.
    Drain, pull cover and inspect? [ just my thoughts - I defer to the experts ]
  6. Mar 24, 2024 at 9:48 AM
    black3rdgen
    STL
    3G on 35s, 5.29s
    It’s filled to the brim with 85w-140, but something that weirded me out when I got it back from the shop was a little oil coming out of the rear left hub. The noise doesn’t get worse under acceleration, I think it’s consistent with wheel speed. No weird vibrations or anything
  7. Mar 24, 2024 at 9:56 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I would bring it back and tell them. The last time I had a ticking sound, my rear end blew up 5 minutes later. You shouldn't have any ticking sounds. If you drain the fluid, you will see if there are any bits in there. If you have a tooth that is chipped, it will start to cause similar sounds. It it was not set correctly could be a bad job and since its from ECGS they will warranty it. Its a pain but at least you have that as an option. I have replaced a few with them in the past, and it was seamless.
    wilcam47 likes this.
  8. Mar 24, 2024 at 10:02 AM
    CB350G
    Western PA
    Oil coming out? :eek: :facepalm:
    Possible damage to wheel bearing / seal during service? Someone forgot to re-install a retainer clip? Take it back to the shop and have them diagnose and fix.
  9. Mar 24, 2024 at 10:07 AM
    black3rdgen
    STL
    3G on 35s, 5.29s
    My issue is they already replaced a set of gears for a similar reason. I’m hoping my ring and pinion gears aren’t shot again..
  10. Mar 24, 2024 at 10:12 AM
    wilcam47
    Will
    Bourbon state
    Doesnt matter they need to fix it. That sounds bad
  11. Mar 24, 2024 at 10:45 AM
    black3rdgen
    STL
    3G on 35s, 5.29s
    Yeah I agree. I’ve been talking to ECGS and they’re gonna warranty the work, but I would really rather not have the truck out for another 2 weeks, just trying to see if the problem is something unrelated to the diff. Guess not lol
    wilcam47[QUOTED] likes this.
  12. Mar 24, 2024 at 1:02 PM
    nudavinci64
    Robert
    Yah I hear ya. It was a 4 week turn around from shipping to and waiting. For replacement. My buddy just had to ship back a new setup as well.
