Need HELP: Coil-over install problem (now)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SCFirefighter, Jul 1, 2010.
  1. Jul 1, 2010 at 8:56 AM
    SCFirefighter
    SCFirefighter [OP] on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    I had the hardest time getting my old struts out. I'm in the process of swapping them for my (now) assembled ToyTec coil-overs with billys.
    I disconnected the sway bar, but still do not have enough room to insert the new assembly. I was able to get the old one out, but barely, by 'screwing' it out between the LCA and the tie-rods (at least that's what I think they are lol).
    The new coils are thicker, and they don't go back in that way.
    I tried everything in my arsenal to disconnect the tie-rod to create room to just slide the coil in, but nothing.
    I tried disconnecting the LCA from the UCA but I cannot get the bolt out of the UCA.
    I'm running out of options. One of them has to go to create room.
    Any suggestions?
    ETA: The toytec help document says to remove the lower balljoint mount, but even with the picture I can't see what they are talking about.
  2. Jul 1, 2010 at 9:00 AM
    stroM-
    stroM- @alteregoadventure
    Santa Rosa, California
    2006 4X4 TRD OR
    You could always just bolt the LCA back up and remove the bolt from the UCA to the spindle... Might give you more wiggle room
  3. Jul 1, 2010 at 9:00 AM
    stroM-
    2006 4X4 TRD OR
    Obviously with the swaybar out though... this picture was just a random on google so you could see.
  4. Jul 1, 2010 at 9:02 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Remove the the spindle from upper control arm. Remove cotter pin, loosen nut and seperate two pieces. Also remove bolt from brake line bracket on UCA. Be careful don't let hub wieght pull down on brake line.
  5. Jul 1, 2010 at 9:03 AM
    SCFirefighter
    Stephan
    Cary, NC
    I tied disconnecting the UCA. I got the pin out, took the nut off, and tried brute force including a hammer to push the bolt out. Nada.
  6. Jul 1, 2010 at 9:04 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    When I've always done it I just disconnected the spindle from the uca, pushed the uca up a bit and slid it in that way.
  7. Jul 1, 2010 at 9:04 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Remove the castle nut from the tie rod end, then take a big hammer and hit the spindle on the side of where the tie rod inserts. You may have to do this 5-10 times hard, but the vibrations created will be enough to pop the tie rod out and you'll be able to move it out of the way.
    Never hit the threads of the tie rod.
  8. Jul 1, 2010 at 9:05 AM
    stroM-
    2006 4X4 TRD OR
    Dont try to hammer the bolt upward, hammer the side of the spindle that sticks out DOWN to loosen everything up.
  9. Jul 1, 2010 at 9:05 AM
    SCFirefighter
    Stephan
    Cary, NC
    Oh wait .. after taking the pin and nut off, all I need is apply downforce pressure? That I haven't tried.
    Edit: What I tried was hammering upwards on the bolt, expecting it to come out of the top of the UCA. Looking at this picture that obviously won't work.
  10. Jul 1, 2010 at 9:05 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Back in the day on the 1st gen trucks.....
    We'd often require the assistance of a 'buddy' to stand ontop of the rotor and push it down with all his weight to give you more room.
  11. Jul 1, 2010 at 9:06 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4R MGM TRDOR Premium Daddy Wagon
    x2
    yeah these things can be a pita! are you trying to do this in your garage, or are you at a hobby shop that has the right tools. cause you are gonna need a tie-rod seperator to get those apart.
  12. Jul 1, 2010 at 9:06 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Or a hammer :D
  13. Jul 1, 2010 at 9:08 AM
    SCFirefighter
    Stephan
    Cary, NC
    Yep yep yep, I just saw that while inspecting that picture. Will try in a minute!
  14. Jul 1, 2010 at 9:08 AM
    SCFirefighter
    Stephan
    Cary, NC
    Rep for perfectly timed smart-ass comment :)
  15. Jul 1, 2010 at 9:10 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Haha, thanks I felt as though MJP2 and strom and the others helped you out that it wouldn't be too ass-ish if I made that comment. :laugh:
  16. Jul 1, 2010 at 9:25 AM
    SCFirefighter
    Stephan
    Cary, NC
    I must be doing something wrong. Can't get it to budge. Standing on the rotor pushing down, and pulling up on the UCA .. nothing. It's a brand new Tacoma, so it's not like stuff is rusted in place.
    Even hammering the hell out of the UCA (from the bottom) while standing on the rotor to create tension isn't doing it. I'm not sure what part 'that sticks out' I should be trying to create downforce pressure (hammer or otherwise).
    Any more suggestions anyone?
  17. Jul 1, 2010 at 9:27 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Don't be afraid to smack the side of the spindle hard. It won't break it. I believe that is the best way to get it separated from the uca.
  18. Jul 1, 2010 at 9:27 AM
    SCFirefighter
    Stephan
    Cary, NC
    "Remove the 2 lower ball joint mount bolts and separate the ball joint from the spindle".
    Is this what I should be trying maybe? Can someone help me accomplish this with maybe a picture?
  19. Jul 1, 2010 at 9:28 AM
    stroM-
    2006 4X4 TRD OR
    Where do you have the truck jacked up at? Middle crossbar right?
  20. Jul 1, 2010 at 9:30 AM
    SCFirefighter
    Stephan
    Cary, NC
    That's where I jacked it, yes. But it's now resting on two stands on the outer parts of the frame.
