Need help confirming correct wheel spacers
Discussion in '1st Gen. Tacomas (1995-2004)' started by T12DELAY, May 11, 2020.
  1. May 11, 2020 at 3:50 PM
    T12DELAY
    T12DELAY [OP] Active Member
    Oregon
    2003 Tacoma | 2.7L | SR5 | 4 Cylinder | 2 Years of ownership
    1 fixed part = 2 broken parts
    buddy of mine at work has a friend who is selling his tacoma wheels and tires, these wheels went on a 2WD tacoma and mines a 2.7L 4WD, it has those universal lug holes where it has like 10 lug holes so itll go on my truck but the hub on mine is to big obviously and these are REALLY nice wheels and tires and he only wants $700 for them, so i figured id need some wheel spacers. i looked around and i found this website that says the factory wheel hub on a 2.7L 4WD tacoma is 106.1mm (idk if the .1 really means anything but thats what it said) and i found some spacers that are 106mm hub centric is there anything im missing? these spacers are 1.5" so idk if thats overkill or if its not gonna get past the hub enough to fit these wheels on
    site i used to find the hub size: spacers i was wanting: https://www.amazon.com/Spacers-KSP-...-4207--8-1---2&vehicleName=2003+Toyota+Tacoma
  2. May 11, 2020 at 4:03 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Are you seriously wanting to put wheels and tires from a 5 lug on to your 4wd?
    Dude. Don't.
    Sebz13 likes this.
  3. May 11, 2020 at 4:04 PM
    T12DELAY
    Oregon
    its not a 5 wheel lug set up, its got like 10 lug holes or something around there, whats the problem with it coming off of a 5 lug vehicle? it can fit 5 or 6 lug wheels
  4. May 11, 2020 at 4:42 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Whenever I see people with universal lugs I wonder who hurt them so bad they had to make that awful choice.
    rds71201 likes this.
  5. May 11, 2020 at 4:53 PM
    T12DELAY
    Oregon
    whats the issue...
  6. May 11, 2020 at 4:55 PM
    T12DELAY
    Oregon
    yea you guys all keep saying universal lugs are bad, and the wheels coming from a 2WD tacoma is bad, no one has yet given me an aswer as to why this wouldnt work and so far everything ive looked at, it WOULD work without any issues, wheels are wheels and if it can fit, why not? never said i was gonna go off-roading or overlanding in them just needed an upgrade
  7. May 11, 2020 at 4:57 PM
    T12DELAY
    Oregon
    i mean, i came here to hopefully get answers or advise from others who know more and so far everyone just says not to do it but not WHY and all my research as leaned more to it WOULD work so unless its a preference thing idk
    Das it mang likes this.
  8. May 11, 2020 at 6:01 PM
    The gold standard
    The gold standard Well-Known Member
    Western mass
    Green 03 v6
    Check tire sizes for what's coming off the 2wd. 4wd usually has 30 or 31" tires stock, and the 2wd has much smaller. It'll make your truck lower and mess your speedometer if they're smaller. I get wanting nice wheels and tires but I seriously doubt that itd be a good fit.
  9. May 12, 2020 at 7:23 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Lol yes wheel adaptors will work as long as the bolt pattern and all that lines up. 5 lug bolt pattern is 5x4.5. no idea if it needs to be hub centric or what so be sure to look that up. If u take the truck offroad at all, remove the adaptors after each time and clean them bc ive heard of em fusing on if u dont keep up with that.
    People on TW will always tell u WHAT to do on here. But not whether u CAN or HOW. Yes u can do the wheel adaptors and go to 5 lug for that deal for wheels. Be sure to clean them like i said and the bolt pattern and all lines up. Have fun building ur truck
  10. May 12, 2020 at 9:06 AM
    jbrandt
    Justin
    Do you realize that it's not just counting the lug nuts, but those lug nuts sit on different diameters. The website you linked to shows the 5 lugs sit on a 5x114.3mm (4.5") and the 6 lugs are 6x139.7mm (5.5").
    Those spacers you linked to won't work anyway, no matter how you slice it. Doesn't matter how many holes it has. The only way to convert from one bolt patter to another is a completely different type of spacer. A two piece design:
    These are NOT what you'd need, but this is the type I'm talking about.
    https://www.amazon.com/Wheel-Adapter-Lug-5-5-135mm/dp/B008L5JCQE
    Most people here are adverse to spacers of any kind. They are, at best, band-aid fixes, and they introduce additional points of failure that just aren't necessary.
    Look, you're wanting to put wheels and tires from a 2wd 5 lug truck onto your 6 lug 4x4. Are you going for this kind of look?
  11. May 12, 2020 at 10:03 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I think he has something like these.
    Which if thats the case it wont fit a 6 lug pattern anywho. And also, those universal wheels just look like something a highschooler would put on his lowered Honda Civic.
  12. May 12, 2020 at 12:52 PM
    jbrandt
    Justin
    I think they look more like something a highschooler might design.
    Blue92[QUOTED] likes this.
