need help debadging
Discussion in '1st Gen. Tacomas (1995-2004)' started by 99toyotaco, Jul 6, 2010.
  1. Jul 6, 2010 at 11:02 AM
    99toyotaco
    99toyotaco [OP] 5L Bar
    Connor
    Eastern Montana
    2017 TRD Off Road Double Cab Long Box
    ok so i got the emblems off but now i have this problem
    what do i do to get rid of this
  2. Jul 6, 2010 at 11:06 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    i used rubbing compound to get the gunk off, also goo gone will take that off pretty easy. once you have done that take some polishing compound or wax to even the faded paint with the relatively "new" paint that was underneath the badges and you should be good to go
  3. Jul 6, 2010 at 11:07 AM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    goo gone
  4. Jul 6, 2010 at 11:08 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    If that residue is the adhesive, get a clean rag w/some Diesel on it & rub it down good, if its still some decal material get a heat gun (be careful with it ) & a plastic spatula gently scrap it off this worked for me....:cool:
  5. Jul 6, 2010 at 11:44 AM
    99toyotaco
    Connor
    Eastern Montana
    can i use hair dryer instead of heat gun
  6. Jul 6, 2010 at 12:08 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    If it gets hot enough i don't see why you can't. It's basically the same thing. I was orginally told to use a hair dryer to get the emblems off.
  7. Jul 6, 2010 at 12:21 PM
    99toyotaco
    Connor
    Eastern Montana
    ok and maybe u can help me with this i need to change the lights that are above the rear view mirror in the 1st gens but i cant figure out how to get the cover off
  8. Jul 6, 2010 at 1:09 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yeah, if you have one that gets hot enough, mine didn't so heat gun was used & like Justin said a light grade of compound will clean things up, wash wax after, as far as the 3rd brake light goes I took mine off , 2 screws on the lens, but pain in the ass to change the bulbs....
  9. Jul 6, 2010 at 3:40 PM
    99toyotaco
    Connor
    Eastern Montana
    i was talking about the map lights inside but i fugured it out
  10. Jul 6, 2010 at 5:46 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Sorry dude, my bad....:D
  11. Jul 6, 2010 at 6:16 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    i used paint thinner on a clean rag and scrubed it off then wiped down the area with another rag soaked with just water to get the paint thinner off before it set in. i tried getting it off with goo gone which works fine its just time consuming.
  12. Jul 6, 2010 at 6:19 PM
    Rbohno
    Rbohno Well-Known Member
    Richard
    Charlotte,NC
    2010 DC TRD OffRoad
    Viper remote start alarm 2.5" Spacer in front, 1.5" spacer in rear, rear TSB performed N-Fab Nerf bars 16" x 8" Vision Warrior wheels 265/75/16 Dura Trac tires
    Mineral spirits works also
  13. Jul 6, 2010 at 6:30 PM
    99toyotaco
    Connor
    Eastern Montana
    ha i will try these hopefully they work my dad is kinda pissed at me right now for doing this haha so i pray that is comes out ok
  14. Jul 6, 2010 at 6:31 PM
    Bullzi511Tacoma06
    Bullzi511Tacoma06 KCCO
    Southeast Louisiana
    2016 MGM Doublecab SR5
    I used WD-40, a rag, and elbow grease.
  15. Jul 6, 2010 at 6:33 PM
    99toyotaco
    Connor
    Eastern Montana
    ya i have tried the wd-40 it didn't work its not the adhesive left its just like a hard outline of the decal. idk ill figure something out
  16. Jul 6, 2010 at 6:34 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    dont worry itll come off, try the paint thinner man but just make sure to clean the area after you use the paint thinner. i felt the same after i took mine off and seen the mess that needs to be cleaned up
  17. Jul 6, 2010 at 6:34 PM
    JAG
    JAG Well-Known Member
    GOO GONE. DO WORK!
  18. Jul 6, 2010 at 6:36 PM
    Aztacotrd
    Aztacotrd Well-Known Member
    Austin
    Az
    O8' V6 Prerunner Accesscab
    I just took mine off about a week ago and to get the adhesive off i used my finger nail and to get the left over residue off I just used windex and alot of elbow grease..... I'm sure goo gone would work but I didn't want to spend the money if I didn't have to.
  19. Jul 6, 2010 at 6:36 PM
    99toyotaco
    Connor
    Eastern Montana
    haha ok that makes me feel better i must just need to scrub away for awhile. im to impatient
  20. Jul 6, 2010 at 6:49 PM
    JAG
    goo gone 5 dolla speciaaaalll
