Need Help deciding a lift
Discussion in 'Suspension' started by Bpfaff45, Dec 13, 2012.
  1. Dec 13, 2012 at 3:47 PM
    Bpfaff45
    Bpfaff45 [OP] Well-Known Member
    Branden
    South Dakota
    06 SR5 TRD off road
    So I have a few conditions. I want a 2 in lift all around and be able to maintain a somewhat regular ride. I understand it will most likely not feel stock. I would like to do this for around or under $300. Is this possible to add a leaf and coilovers for this price?
  2. Dec 13, 2012 at 4:03 PM
    RadRed06
    RadRed06 Christ Follower
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    For around $300 you can get some 884 or 885 coils with an AAL or Bilstein 5100 shocks that are adjustable and an AAL. Most coilovers are pretty pricey.
    Check out toyteclifts.com
  3. Dec 13, 2012 at 4:17 PM
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    MA/VT
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    ^this
  4. Dec 13, 2012 at 4:42 PM
    Bpfaff45
    Branden
    South Dakota
    06 SR5 TRD off road
    I have bilstein shocks already becuase I have a TRD off road.. so all i would need is the 884's and an AAL? This package is suitable?
  5. Dec 13, 2012 at 7:05 PM
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    I was referring to the 5100 adjustable shock, much different than the stock off road shocks. But yes the 884s and an AAL will get you around a 2 inch lift. Since you have an access cab you should get somewhere in between 2 and 2.5 inches in the front with the 884s.
  6. Dec 13, 2012 at 7:07 PM
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    If you choose to add the top plate spacers to the 884s you should get closer to 3 inches up front.
  7. Dec 13, 2012 at 7:08 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    the other member was referring you to these Bilstein shocks that are adj.
  8. Dec 13, 2012 at 8:02 PM
    Bpfaff45
    Branden
    South Dakota
    06 SR5 TRD off road
    Alright I gotcha. Thanks do the help. I got the 884's and AAL kit. Pictures soon to come :)
  9. Dec 31, 2012 at 6:24 PM
    Bpfaff45
    Branden
    South Dakota
    06 SR5 TRD off road
    Here are the results after the 884 coils, spacer, and AAL
  10. Dec 31, 2012 at 8:32 PM
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    Nice! How do you like the ride?
  11. Dec 31, 2012 at 11:02 PM
    Bpfaff45
    Branden
    South Dakota
    06 SR5 TRD off road
    Definitely rougher and have been experiencing some wierd humming even after the alignment. But i love the look of the lift. Thanks for the help and happy new year!
  12. Dec 31, 2012 at 11:09 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    What shocks are you running with those coils ?
  13. Jan 1, 2013 at 12:36 PM
    Bpfaff45
    Branden
    South Dakota
    06 SR5 TRD off road
    Im running the stock bilsteins.. they have seen their better days tho. Ill need some new ones here soon. they have been on there for 115,000 miles!
  14. Jan 1, 2013 at 1:18 PM
    OZ-T
    Peter North
    British Columbia
    Didn't think you could run stock shocks with extended coils
    That might explain your crappy ride
  15. Jan 1, 2013 at 1:26 PM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    What size tires and did you have the tsb leafs?
  16. Jan 1, 2013 at 3:41 PM
    Bpfaff45
    Branden
    South Dakota
    06 SR5 TRD off road
    Would 5100's be a good option? Or would Fox make something better for the same price?
  17. Jan 1, 2013 at 3:44 PM
    Bpfaff45
    Branden
    South Dakota
    06 SR5 TRD off road
    265/70's And i just added a leaf making the total count 4. The leaf was from toyotec, the other 3 stock.
  18. Jan 1, 2013 at 3:50 PM
    OZ-T
    Peter North
    British Columbia
    5100's would be fine
  19. Jan 1, 2013 at 6:30 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    I'm looking at doing pretty much the same setup as you, from what I've read the 5100's seem like a good option. Btw the truck does look good.
  20. Jan 1, 2013 at 9:57 PM
    Bpfaff45
    Branden
    South Dakota
    06 SR5 TRD off road
    Thanks! But sweet upload some pics to this thread when you get everything done!
