Need help deciding if a 3 inch lift on a 4cyl is a good idea
Discussion in 'New Members' started by CHarrison32, Apr 24, 2014.
  1. Apr 24, 2014 at 2:41 PM
    CHarrison32
    CHarrison32 [OP] Well-Known Member
    Cody
    West Virginia
    2011 AC 4x4
    Bilstein 5100 all the way around, wheelers 3-leaf progressive AAL, Camburg Ball-joint UCAs, SCS SR8, BFG KO2 20% tint, WeatherTech floor mats, Tacoma bed mat, tonneau cover
    I know there are several posts about lifts and I've read just about every single one if them. I can't decide on getting a bilstein 5100 ride height adjustable leveling kit or a 3 inch lift. I would really like a 3 inch lift if the gas mileage and other problems don't occur. And are lift kits easy to install yourself? I need help lot of questions left unanswered I can spend under about $1000 on a lift since I'm still in school but saving up for other fabrications if the lift is a good idea.:cool:
  2. Apr 24, 2014 at 2:44 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Tires change the MPG--lift does not.
  3. Apr 24, 2014 at 2:56 PM
    CHarrison32
    Cody
    West Virginia
    2011 AC 4x4
    What size tires would look fine with a 3 inch lift?
  4. Apr 24, 2014 at 3:50 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Your best bet for info on maximum(and best) size is in the wheel and tire section.
  5. Apr 24, 2014 at 3:52 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    let me know if you have difficulty finding the section--its left
    "WHEELS AND TIRES"
  6. Apr 24, 2014 at 3:54 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    lifts--billies-can be done in the driveway-YES-you can do it at home.
    You will need a spring compressor for the fronts-auto parts stores loan them for free.
  7. Apr 24, 2014 at 3:55 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I say go for it and just cause your a 4cyl doesnt mean you cant lift it haha. You can find a descent full suspension lift for under $1K and install it yourself with a friend or 2. You can go up to 33" tires with a 3" lift with some minor trimming.
  8. Apr 24, 2014 at 4:07 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Actually, it can, and it did to mine.
    I went from 24 to 22 just from installing my lift.
    If you don't believe me, pick up a physics book and read the chapter on aerodynamics.
    33's.
  9. Apr 24, 2014 at 7:14 PM
    CHarrison32
    Cody
    West Virginia
    2011 AC 4x4
    I think I'm going to go with the lift. In the future, guess this high schooler needs to start cutting grass.
  10. Apr 24, 2014 at 7:15 PM
    CHarrison32
    Cody
    West Virginia
    2011 AC 4x4
    What would be the best lift for under 1k?
  11. Apr 24, 2014 at 7:45 PM
    cfagan14
    cfagan14 GaTacoma
    Atlanta
    2017 DCLB 4X4 TRD OR Quicksand
    Do you have an auto or stick? Also your mileage will go down with larger tires, I'm assuming you would want 285's?
  12. Apr 25, 2014 at 12:06 PM
    CHarrison32
    Cody
    West Virginia
    2011 AC 4x4
    Stick I'm running 265 right now on stock and it'll be awhile before I purchase new tires so I'll just run smaller tired for a while
  13. Apr 25, 2014 at 12:13 PM
    VAYoder4167
    VAYoder4167 Well-Known Member
    Frank
    Lynchburg, VA
    Lifted 04 toyota tacoma sr-5
    Magnaflow dual catback exhaust, 5100 bilsteins all around with 1" body lift and stock coils, 33" BF Goodrich sitting on a set of 15" Alloy Ion wheels
    Well I run 33x12.50x15 with the 4 banger and have a spacer lift now and I just ordered the bilsteins 5100s all the way around and gotta order an AAL buty little 4 banger hauls the tires around fine but there is a slightly power decrease but not too much.
  14. Apr 25, 2014 at 1:48 PM
    CHarrison32
    Cody
    West Virginia
    2011 AC 4x4
    What's the gas mileage like? And the power is about the same?
  15. Apr 25, 2014 at 1:49 PM
    CHarrison32
    Cody
    West Virginia
    2011 AC 4x4
    Is the spacer lift rough like everyone says? That would be a cheaper price
  16. Apr 25, 2014 at 1:54 PM
    VAYoder4167
    Frank
    Lynchburg, VA
    The gas mileage is about 18-19 most times sometimes alittle les but it ain't bad and no the power loss isn't too significant but it's there you add a few things like headers and intake and whatever you'll make up for it. Mine still has a lot I pep in its step and I have yet to supercharge it so. On the issue of the spacer lift DON'T DO IT!!! It's rough that why I'm going to the bilstein 5100's all the way around with AAL.
    If your going to lift do it right it's rough as hell with the spacer lift especially when your trail riding.
  17. Apr 25, 2014 at 2:29 PM
    CHarrison32
    Cody
    West Virginia
    2011 AC 4x4
    Alright I guess I'm saving up for a lift and soon then after a CAI thanks for your help I'm looking forward to getting a lift in the near future
  18. Apr 25, 2014 at 2:30 PM
    CHarrison32
    Cody
    West Virginia
    2011 AC 4x4
    Or would bilstens 5100 adjustable ride height in the front and bilstens in the rear just do it justice
  19. Apr 25, 2014 at 2:39 PM
    RaleighTaco
    RaleighTaco Well-Known Member
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    Under $1000 2.5-3'' lift for your truck.....
    Old Man EMU 884's- $160+shipping (wheelers offroad)
    Bilsten 5100's all around set at 0'' in the front- $400 or very close to it
    2in add a leaf in the rear- $80+shipping (wheelers offroad)
    Perfectly capable offroad and smooth onroad
    and looks fine with 265's
    Only difference is i have 17's wrapped with 265's
  20. Apr 25, 2014 at 2:41 PM
    CHarrison32
    Cody
    West Virginia
    2011 AC 4x4
    I have 17s with 265s
