Need help deciding on 885 vs 884 for access cab
Discussion in 'Suspension' started by wallytaco, Feb 26, 2010.
  1. Feb 26, 2010 at 11:44 AM
    wallytaco
    wallytaco [OP] Active Member
    Pittsfield, MA
    '10 MGM Access V6 OR
    I finally caved and bought a '10 Access Cab 4x4 V6; been wanting a Tacoma for about ten years and finally pulled the trigger. Found this site and it has been an invaluable resource.
    I've tried searching and even found one thread that started to answer the question, but I'm hoping I can get a little more detail. I've decided to order the OME lift kit, but can't decide between 884s and 885s. Chris4x4 indicated that the sagging issues associated with 884s on an access cab have been resolved. However, in the same thread, someone else advocated for going with the 885s. I was hoping for feedback from people running either setup.
    I have no plans of putting a heavy bumper on, just want to ensure the full 3" lift. If I go 885 do I risk stiffening the ride too much? Should I just stick to 884s?
  2. Feb 26, 2010 at 11:59 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I roll with 885s and I love the ride. I don't think you'll be upset either way.
  3. Feb 27, 2010 at 6:31 AM
    wallytaco
    Pittsfield, MA
    Thanks Brunes. Did you put in the top plate spacers or skip them with the extra height of the 885s?
  4. Feb 27, 2010 at 6:42 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I did not get a full 3 inches with just the springs and I have not had time to work the spacers into the kit. I expect that I will be AT or JUST under 3 inches when I do.
    I'm also thinking about swapping to 886s before I try....
  5. Feb 27, 2010 at 6:51 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I would go the 885's with the top plate spacer. I think you'll be happy.
  6. Feb 27, 2010 at 6:56 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    I run the 885's with top plates and I am pretty happy with them. Also, consider some 5100 series shocks.
  7. Feb 27, 2010 at 6:58 AM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    another vote for the 885's. that's what i'm running and they ride smooth!! :thumbsup:
  8. Feb 27, 2010 at 7:07 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    From what I have found the 885s are 10 mm taller than the 884s. Same spring rate and wire diam. just 10 little mm taller.
  9. Feb 27, 2010 at 7:07 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I'd say 885's. I personally would rather my truck be a little on the stiff side than the mushy side. Also, if down the road you decide to add a Westin bar, Avid bar, heavy plate bumper, winch, etc. You'll most certainly be better off with the heavier coils. Put the trim packer on the driver's side too. The top plate spacers need longer studs so I'd say go ahead and put them on while the struts are torn apart. If you don't like them, it only takes about an hour to pull out the spacers while leaving the long studs on the truck. Adding them later means you have to tear the whole strut apart again to install the longer studs, adding a few hours to the job (sounds like the boat Brunes is in).
  10. Feb 27, 2010 at 7:32 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I just have to swap the springs- I have the longer studs in place already. I wasn't sure about getting a bumper....but I'm going to do it...so I want the 886s.
    I vote for the plates too!! (I think I forgot that part before...)
  11. Feb 27, 2010 at 8:08 AM
    mtlheadhntr
    mtlheadhntr Well-Known Member
    Richie
    Live in South GA / From Milwaukee, WI (WI boy at h
    2005 Silver TRD Offroad 4x4 SR5
    3" Suspension lift; 884 OME front coils w/ 2" ALCAN AAL, General Grabber AT2s 265/75-16, Black powdercoated nerf bars, Black UWS low profile tool box, Blacked out badges, EGR In-Channel Vent Visors, Sockmonkey bedside decal, Keyed hose clamp tailgate mod, 15% tinted windows in front and blacked out in the rear, Weathertech digital fit liners front and back, Wet Okole seat covers, Sirius Starmate 5, and this week will be the BHLM and paint wheels Black!
    I have the 884s and love them. I still run the stock shocks but will probably swap them out for OMEs all around. I have not noticed any saging. If it sagged, it is very minimal.
  12. Feb 27, 2010 at 9:00 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    this is true. same spring rate only the 885's are a bit taller. ARB shows the 885 for your truck! thats what i would go with. it should give you 3"'s of lift with just the coils.
  13. Mar 16, 2010 at 4:51 PM
    huff.jeremy
    huff.jeremy Well-Known Member
    Illinois
    2010 MagGray SR5 Access Cab, 4x4, 2.7L, 5spd
    OME 884's, OME shocks, Wheelers 1.5" AAL, Light Racing UCA, Jason Fiberglass top, URD Short Shifter, Fog Lights
    I agree with the above poster who said that they would prefer stiffer springs than mushier springs, just to be on the safe side (especially if I add weight to the front in the future). Because of this I was about to order 885's, then realized that I have a 2.7L. Would I ever have any worry's running just 884's on a 2.7L Access cab? (2010 4x4)
    EDIT - oops... just did a bit more research and found that 885's will give a bit more lift than I wanted. This post can be deleted.
  14. Mar 16, 2010 at 5:31 PM
    Hunter'06FLKY
    Hunter'06FLKY Well-Known Member
    Central Florida
    08 Access Cab SR5 4x4
    Bilstein 5100's on all 4 corners, OME 884's, Toyotec AAL, Differential Breather, PIAA Fog's, K & N Air Filter, Definity Dakota M/T's, Cherry Bomb Extreme High Clearance
    i was actually wondering the same exact thing...
  15. Mar 16, 2010 at 6:08 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Here are my thoughts. I have mulled this very issue over time and time again. For me, 884's seem the way to go with either 5100's or the OME shocks. Here is why I think that (for me at least). I have no intention of ever putting a bumber or bull bar on my front, so extra weight is not an issue for me. I have the TSB rear springs so my rear end is a tad higher than normal thus driving my nose down a tad. Not really an issue, but it does look a tad bit off with the space in the rear wheel well vs the front.
    If I had gone the 885 route, I would most likely get the OME shocks which are more money. Also, the 885's will put you right around 3" or so give or take. At this height, new UCA's would be a smart move. It is not needed, but I feel that it should be done if you are up 3"'. Now, there will be a good deal of space in the wheel wells. Not to mention maybe rear-leaf pack to kinda even the look out. This will require new tires and perhaps rims. It is my beleif that if a person goes down this road with a 3" lift in the front, all of the above will happen at some point. Pretty expensive IMO.
    I am looking for a bit of lift in the front to offset my look in the rear after the TSB. I could care less about 3". I just want a certain look. I do not want to buy new rims and tires now. When I do need tires, keeping the stock rims is the direction I will go.
    The 884's give me the lift I need in the front and also allows me to run either the stock shocks, 5100's or OME's. 885/886 are recommended only w. OME shocks (even though people do otherwise and are fine). So lets say I keep the stock shocks, 884's are ~$160/pr. and ~$50 to install. Pretty cheap to me.
    In the end, it comes down to what YOU are looking for. If you needs are in line with my needs, I urge you to look into the 884's. Alot of 885's guys on here have amazing trucks with the 885 3" lift. If that is the look you are going for, spend the cash if you have it or save it and do it right. Just know with 885's come with other expenses that the 884's might not have.
    Hope that helps someone.
  16. Mar 16, 2010 at 6:28 PM
    pokeng
    pokeng Married With Children
    North of Austin/West of Nashville
    2009 DC TRD Off Road 4x4
    Foldacover G4 Elite, Deflapped, TRD exhaust, Webasto Hollandia sunroof, Katzkin leather seats, Dynolock, Sockmonkey decals, oem bed extender, all-weather mats and bed mat
    Well said. I posted a thread a while back asking similar questions. Wanted to level out my ride after the TSB and achieve the best possible ride and stay away from the expense of new UCAs for now. Chris4x4 recommended the 884's. Placed my order last week and should arrive anyday now. Both the 884s and 885s use a new 90000 shocks, so it will be interesting to see the results.
  17. Mar 17, 2010 at 8:31 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    Please report back once you get them on and drive around a bit. I am going with the same exact setup and would love to know how you like it. One of these days I have to get around to ordering my stuff. Hopefully with the good weather around the corner I will get it done. Just always busy!
    best of luck with the new springs!
