Need help deciding on speakers
Discussion in 'Audio & Video' started by malander, Jan 4, 2012.
  1. Jan 4, 2012 at 7:50 PM
    malander
    malander [OP] Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I know asking for help choosing speakers can be a bit subjective, but I've narrowed it down to these three and would like to know if anyone has any experience with them or could offer some advice regarding speaker selection. These will be powered only by a pioneer deck..no amp yet. Thanks for taking a look. Oh yeah, it's for a first gen if that matters, and just the fronts/tweeters
    http://www.crutchfield.com/App/Prod...=01|107DB571&compareItems=01|130TSA1304&g=400
  2. Jan 5, 2012 at 5:30 AM
    XJBaylor
    XJBaylor Well-Known Member
    Keith
    Plano, TX
    06 DCLB TRD Sport 4x4
    King coilovers with remote reservoirs, Deaver 12 leaf pack with 5100's, TRD exhaust, Kenwood 6160, Anthracite Sport Wheels
    The Polks have the highest sensitivity of those you listed, a big plus running off of HU power. If I were shopping from Crutchfield with the same price range I would be looking at THESE SPEAKERS.
    I would actually take the Focals off of that list, as I realized their sensitivity rating is based on 2.83V not 1 watt. If it were me I would focus on the Polk db521 or the DXi525. They look eerily similar based on their specs.
  3. Jan 5, 2012 at 5:54 AM
    saitcho
    saitcho Well-Known Member
    New Orleans
    '11 DC 4x4 trd off road
    why 5.25 instead of 6.5? just bc?
  4. Jan 5, 2012 at 6:09 AM
    jackhart
    jackhart Well-Known Member
    11 DCLB
    i don't think 6.5's will fit in the OP's ride. he's got a 1st gen i think.
    aside from separates, the polk mm (mobile monitors) are some of the best car audio speakers i've heard. if i could afford them, i would go with them in a heartbeat. they do sound even better when powered with a very clean amp, but even so, that would be my starting point.
  5. Jan 5, 2012 at 7:36 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Lives: Pyeongtaek, South Korea/Home: Leesburg, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    1st gen's take a 6.5 speaker
  6. Jan 5, 2012 at 9:19 AM
    XJBaylor
    Keith
    Plano, TX
    If that is true, the OP should look at the Polk db651. The can be had for something like $70 on Amazon.
  7. Jan 5, 2012 at 1:04 PM
    malander
    max
    01 limited trd 4x4
    I just picked out the speakers crutch field said fit. From what I've researched the 1st gens have an odd size up front that can be replaced with a few different sizes. I will take a closer look into Polk though thanks
  8. Jan 5, 2012 at 1:30 PM
    XJBaylor
    Keith
    Plano, TX
    Nothing special about Polk, but in your price range it is what I would go with, though everyone's ears are different. Just make sure you focus on speakers with a high (92+ db) sensitivity. That is also not a magic number, but I know there are quite a few speakers in your price range that fit that description.
  9. Feb 8, 2012 at 1:42 PM
    malander
    max
    01 limited trd 4x4
    My polk db571s will be here tomorrow! What do I need to know about removing the door panel? I searched around but didn't find anything very good
  10. Feb 9, 2012 at 12:46 AM
    DevL
    DevL Well-Known Member
    What Focal were you considering? If it was 165cvx they are NOT loud. They are my rear fill speakers and my K2 components are easily twice as loud while having lower sensitivity.
  11. Feb 9, 2012 at 12:55 PM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    Door panels are easy to pop off 2 screws and yank. As for speakers I am very very impressed with my dls comps I just put in defiantly was not expecting this kind of mid bass from a shallow mount speaker
  12. Feb 17, 2012 at 7:44 AM
    malander
    max
    01 limited trd 4x4
    Thanks. Will I need anything special to actually install the speakers? Just wire and baffles and screws right?
  13. Feb 17, 2012 at 7:45 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    i just got a pair of boston speakers, a tad pricey but they sound great
  14. Feb 17, 2012 at 10:40 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    You really should pop off the door panel and see what you've got in there. My '01 Double Cab had 6x9's in all 4 doors. And as far as the speakers I'd go with the Polk Audio's that XJBaylor posted in his comparisons link.
  15. Feb 17, 2012 at 11:49 AM
    XJBaylor
    Keith
    Plano, TX
    I haven't seen the inside of a 1st gen door, but you may also need a set of crimpers and spade terminals.
  16. Feb 17, 2012 at 2:13 PM
    Warhorseforever
    Will
    Sand Lapper
    When I did mine the first time I had to cut the plastic on the back of the stock speaker rings to make my kenwoods fit because they were deeper than the stock unit so a dremel would help, if you're broke like me just use a multi purpose sawzall blade and some elbow grease. Did you order from crutchfield and get the adapter? If not then a good idea would be to tape the wires together and mark them(+&-) before you snip them so that you know which one's go where because when I did mine there are 2 wires that go to positive and 2 which go to negative and I didn't mark them and had to look around for a half hour trying to figure out which one's were which.
  17. Feb 17, 2012 at 6:59 PM
    malander
    max
    01 limited trd 4x4
    Crutchfield said 6x8s (5x7s) would fit. I guess I'm just gonna have to take it apart and figure it out
  18. Feb 17, 2012 at 7:15 PM
    Warhorseforever
    Will
    Sand Lapper
    Most 6x9's will also work as 5x7's they usually have little tabs that will allow for a smaller/bigger mounting situation. Crutchfield usually get's it right but there are a few car's that I've helped with or have done that CF had the sizes wrong. Just pull the door off and take a look, you don't even need to take it all the way off you may just be able to pull up the bottom and look up there with a light.
  19. Feb 18, 2012 at 8:39 AM
    malander
    max
    01 limited trd 4x4
    Alright it is judgement day. One last quick question..The crutch field master sheet has instructions to strip the wires behind the speaker harness. Can I just cut off the old speaker harness instead? Seems like a pain to have to strip a section and not the ends.
  20. Feb 18, 2012 at 8:48 AM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    If you don't ever plan to put the factory speakers back in then just cut them and strip the ends. The only reason for the way they suggest is to keep the stock connectors.
    But as far as which speaker, my advice is to find them in a store if you can to listen to each in person. See which sounds best to you. All 3 brands you have picked make great products. Just a matter of which fits your taste and plans.
