Need help deciding on subs
Discussion in 'Audio & Video' started by dwsalley95, Jan 11, 2012.
  1. Jan 11, 2012 at 1:55 PM
    dwsalley95
    dwsalley95 [OP] Well-Known Member
    Dylan
    Columbia
    07 TRD SPORT
    Hey guys looking at getting this package for my 2007 DCLB next month. I was wondering if they look like pretty good subs and an amp for the price listed. Also, there is the same package with a 750 watt amp for about $100 more would that be a better deal or too much power for the two 10' subs? Let me know what ya think or if you have any other ideas/suggestions. The link is listed below.
    http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/9096856/vpcsid/15701048/SFV/30046
    Thanks
  2. Jan 11, 2012 at 2:29 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    They are different subs with each package. One are the Comp 10's, the other is the CVT 10's.
    Power of the amp on both packages suits the subs.
    They will probably be sufficient for adding bass to the truck. There is better equipment out there, and there is worse.
    They are pretty common subs, see if some local shops have them you can go look at.
  3. Jan 12, 2012 at 1:53 PM
    dwsalley95
    Dylan
    Columbia
    07 TRD SPORT
    Thanks for all the info man and Im pretty sure I've decided on the 400 watt package. I might also add a touch screen indash any suggestions that wont cost a fortune that are a pretty good deal for the money??
  4. Jan 12, 2012 at 2:31 PM
    dwsalley95
    Dylan
    Columbia
    07 TRD SPORT
  5. Jan 12, 2012 at 5:03 PM
    GeauxTigers
    GeauxTigers //TRD
    Caleb
    Sterlington, Louisiana
    '14 TRD DCSB Off-Road 4x4
    265/70/17 BFG KO2/17"x7" Pro Sema Wheels/OME 884/Bilstein 5100 front & rear/HeadStrong 1/4" TP spacer/Deaver 1.5"-2" AAL/Mud-Flap delete/Westin Bed mat/UltraGauge/ WeatherTechs/AFE Pro Dry Drop in Filter/debadged/AVS in-channel window visors/color-matched OEM grille/Kicker 6.75" Components in front door/Alpine KTP-445U power pack behind factory head unit/
    i have that same headunit. i bought it back in july for 350 from crutchfield. i absolutely love it. one of the many good things about ordering it from crutchfield is that they send you everything you need to install it (the dash kit and wiring harness) plus you get the install directions and full support from them.
  6. Jan 12, 2012 at 7:20 PM
    dwsalley95
    Dylan
    Columbia
    07 TRD SPORT
    awesome info man thanks for the feedback. So the one off Amazon won't come with everything I need to wire and install it (trim piece that surrounds it too)?? Also, did you have your subs installed at the same time or the in dash first because I'm having subs installed next month... Sorry for all the questions and again thanks for the help
  7. Jan 12, 2012 at 7:22 PM
    dwsalley95
    Dylan
    Columbia
    07 TRD SPORT
    just read more and found out it comes with everything needed to install including the trim.(at the bottom if you want to look for yourself)
  8. Jan 12, 2012 at 7:24 PM
    GeauxTigers
    GeauxTigers //TRD
    Caleb
    im almost certain that it will not include everything that you need. i currently dont have any subs. i received my 4 polk db 6.5's from crutchfield today and going to install them this weekend and see if i can go without a sub or not.
  9. Jan 12, 2012 at 7:27 PM
    GeauxTigers
    GeauxTigers //TRD
    Caleb
    the trim ring that it is talking about is just a small black piece that goes around the radio so. ill try to dig up a pic of mine and show you
    here it is. notice the black trim piece that is around the radio itself? that is what they are saying is included.
  10. Jan 12, 2012 at 7:37 PM
    GeauxTigers
    GeauxTigers //TRD
    Caleb
    also, the wiring harness they include is different than the one you get from crutchfield. crutchfield will send you a wiring harness that is specific to YOUR vehicle so you dont have to splice into your dash wires like you would with the one thats included with the Amazon one.
  11. Jan 12, 2012 at 7:47 PM
    dwsalley95
    Dylan
    Columbia
    07 TRD SPORT
    a lot of great info here thanks for the help. Still a bit up in the air wondering if someone has ordered the same package from Amazon?? Also, once I get my in dash should I wait to have it installed with the subs or should I just do it on my own??
  12. Jan 12, 2012 at 8:22 PM
    canadaman
    canadaman Active Member
    Canada
    07 TRD Sport
    I would suggest doing it on your own. The toyota dash is VERY easy to take apart. If you want to save yourself the trouble, run a remote wire and a set of RCAs to where the sub will be when you install the deck. Then you will not need to pull your dash apart again when you install the subs. You will only need to run the power cable to the battery. ********* has some good vids for installing subs. People on this site should be able to help if you get stuck. Do you have much experience with wiring?
  13. Jan 12, 2012 at 8:32 PM
    dwsalley95
    Dylan
    Columbia
    07 TRD SPORT
    appreciate the advice and no I don't have much experience with wiring. I have taken out my stock radio before and installed the iPod adaptor/aux cord. I have a few buddies who have wired their subs and a friend who lives down the road drives a DCLB just like mine with the same package I'm installing. Hopefully we can figure it all out. Thanks again for the tips every bit of info is greatly appreciated
  14. Jan 13, 2012 at 12:17 PM
    NOCENTS
    NOCENTS Well-Known Member
    Arm pit of Cali
    08 TRD DC needin some lovin
    loooooong list of mods coming as soon as I finish the audio/video system
    X2
    I ran my video outs(to hook up monitors for the back seat),pac steering wheel control adaptor, RCA's for the front and rear doors as well as the subs and rear view camera wiring. This way it is easier to add the rest of the "goodies" as I have time and cash to expand my system.
    The set up on Amazon dose not come with the double din adaptor for your taco or the wiring harness adaptor.Harnes is well worth the 10.00 can do all your soldering or crimping out of the vehicle. Also can be changed back to stock if you need to.
  15. Jan 17, 2012 at 7:08 PM
    dwsalley95
    Dylan
    Columbia
    07 TRD SPORT
    okay sweet i think i have decided on the headunit and other input on the sub package?? anyone?? thanks for the tips on the install, they will make things a ton easier
  16. Jan 19, 2012 at 6:52 AM
    NOCENTS
    Arm pit of Cali
    What subs are your friends running down the street? Are they running the same set up? If so and it sounds good then go with it. I have been battling with which subs to add my self trying not to go with the JL 10w1v2. Was going to to a alpine Type S 10 in a ported box but 2 tens will be louder, and I do want louder deeper bass but can't afford the 13TW5 that I would like to get. There is not much room back there for full size subs and even less air space. I think those supercrew/eBay/hifonics boxes are not optimum air space for those subs, but I have never heard them so not sure if what they do have is enough to make it sound good. I know JL is coming out with a new 10 and a 12 TW3 slim line and I might wait to get those or just save up and get the TW5. But check out other DC's and see if you want more or less and you can go from there.
  17. Jan 20, 2012 at 9:20 AM
    beauxxbennett
    beauxxbennett Active Member
    Beau
    Currituck
    06 Tacoma
    Aries bull bar, PA system, aftermarket head unit, and JL stealthbox.
    I just bought the stealthbox for my truck and haven't gotten to install it yet does anyone else have one installed already?
  18. Jan 26, 2012 at 3:53 PM
    dwsalley95
    Dylan
    Columbia
    07 TRD SPORT
    my buddy down the road has the exact same set up from the same place and his sound great. im looking to buy this http://www.amazon.com/Pioneer-AVH-P2300DVD-Double-DIN-Receiver-Control/dp/B004HW6F7E
    headunit and have it installed with the subs at the same place he had his done all before the end of feb.
  19. Jan 27, 2012 at 10:39 AM
    NOCENTS
    Arm pit of Cali
    Sounds like a good plan. And you know how it sounds so wont be spending tons of money to find out you dont like the way it sounds.
  20. Jan 29, 2012 at 12:49 PM
    dwsalley95
    Dylan
    Columbia
    07 TRD SPORT
    Exactly I'm supper excited about the plans. I'm interested to hear what you end up doing so make sure to post once you know/do it.
