Need help deciding what to buy?
Discussion in 'Suspension' started by Craxellll, Feb 28, 2023.
  1. Feb 28, 2023 at 7:43 AM
    Craxellll
    Craxellll [OP] Member
    2019 Silver Tacoma SR5
    I’ve been trying to figure out what direction I want to go with suspension but I can never make a final decision so I’m looking for advice.
    I own a 2019 SR5 2WD Tacoma and I’m currently in college so I don’t do any trail riding or barely any off roading so I don’t need anything fancy.
    I’m trying to get 3-4 inches of lift without sacrificing ride quality. My budget is $1,000 for the lift but If I can save money while not sacrificing ride quality then less is always better :)
    What options do I have? Also would love if someone could make it simple to understand.
  2. Feb 28, 2023 at 7:47 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    You want 3-4inch of lift? Without sacrificing ride quality? You're a college student on a tight budget?
    Simple. Keep it stock.
    Stay away from useless lifts it'll just make you shell out $$$$ in the future from fkd up cv axles, needle bearing etc.
    1k in a lift also leaves u no cash for bigger tires (which will cost more than your lift) and fixing all the vibrations and complications from your non-functional lift.
    It will become a useless money pit.
  3. Feb 28, 2023 at 10:31 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    There are plenty of ways to do it. But when lifting a truck inherently there are other issue that need to be taken into consideration. What size tire to what to run? How much lift to run it? Will I need UCAs to correct alignment? Possible driveline vibrations and what’s needed to fix. Etc. I would budget 3-5k for lift , tires, wheels etc. You won’t need to worry about cv issues or needle bearing issues as you have a Preunner.
  4. Feb 28, 2023 at 10:56 AM
    Craxellll
    I was thinking about running 33 inch tires on 18 inch rims and a little bit of offset but I’m clueless when it comes to how wide I can fit and I’m guessing I need a 3-4 inch lift for it.
  5. Feb 28, 2023 at 11:37 AM
    gotoman1969
    I’d run 17”’ wheels there are more tire choices. If you wanna go 4” since you have prerunner id use a lift knuckle like max trac (then you can get away w/o a aftermarket uca) If you decide to run a true 33 depending on wheel offset will dictate how much and what will need trimming, if you’ll need to do a cmc etc. it’s not just lift 4” and throw on a set of 33s.
  6. Feb 28, 2023 at 11:39 AM
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    Consider looking for OEM take offs from a pro also.
  7. Feb 28, 2023 at 11:44 AM
    Ryan's Taco
    Ryan's Taco Well-Known Member
    Prince Edward Island
    24 TRD Offroad manual
    I had an 18 2wd just do a front spacer lift like 1.5-2 then some bigger tires but I wouldn't go to crazy.
  8. Mar 6, 2023 at 3:22 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    This!! 2nd go with a spindle lift.
  9. Mar 6, 2023 at 3:25 PM
    hanlan75
    hanlan75 Well-Known Member
    NNJ
    2023 White Taco SR, 2022 MSM Tesla Y P
    Not for nothing, but if you’re not going off-road and hitting the obscure trails then I’d skip the lift and just save your cash. The truck is pretty capable as it is.
    wi_taco and LeakyAC like this.
  10. Mar 6, 2023 at 3:27 PM
    Bishop84
    Bishop84 Well-Known Member
    Spindle lift all day. 1-2" block in rear. 5100 shocks. EZ PZ.
    Clearwater Bill likes this.
  11. Mar 6, 2023 at 3:48 PM
    Clearwater Bill
    Billy
    Largo Florida
    It's 2wd, so it's a looks lift. Your $ would likely be better spent elsewhere.
    But if you must burn cash, follow @Bishop84 advice
  12. Mar 6, 2023 at 4:04 PM
    Craxellll
    thank you, I think I’m gonna go with this!
  13. Mar 6, 2023 at 4:08 PM
    mushroom_man7
    mushroom_man7 Well-Known Member
    you got a lot to learn, what you wrote really shows how new you are. instead of buying things, you should be reading.
    LeakyAC likes this.
