Need help diagnose start issue - maybe battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by amansker, Jun 27, 2021.
  1. Jul 3, 2021 at 10:34 AM
    Waasheem
    Waasheem
    2007 xrunner
    Get the cheapest one you can find or a Amazon counterfeit so you can go through the trouble to get the starter out, take it apart, install the kit, put it back in, have it fail again. Or get a good one that’s known to be proven good, do it right once.
    https://www.nationsstarteralternator.com/
    Jimmyh likes this.
  2. Jul 3, 2021 at 11:13 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I agree. Nations they provide a new plunger where a many kits do not.
  3. Jul 4, 2021 at 5:29 AM
    rblount2
    rblount2 New Member
    Richard
    2008 Prerunner TRD Sport
    Jimmyh likes this.
  4. Jul 8, 2021 at 9:44 AM
    rblount2
    rblount2 New Member
    Richard
    I got it on Monday, and installed it that afternoon. Unfortunately it still didn't start. I had purchased a voltage meter and ran a test from the battery to the starter and discovered that it wasn't getting enough juice to the starter. I found almost 3 inches of corrosion under the insulation on the negative wire. Cleaning the terminals was the first thing that I did, but didn't notice the swelling in the cable wire until I started tracing the wire toward the area where they are all wrapped together. After cutting the corroded piece of wire out (thankfully there was still just enough left to make it to the post), I got it all hooked up. It's starting like a champ now!
  5. Jul 8, 2021 at 10:33 AM
    amansker
    amansker [OP] Ramen!
    Andy
    San Diego, CA
    2010 AC 4x4 6cyl Auto TRD Sport
    I waited a week to post. The X2Power battery cranks right up every day. So, the battery fixed the symptom. Perhaps the solenoid is making poor contact and the new battery provided the extra spark needed. Time will tell.
    ohcaltexscar likes this.
  6. Jul 8, 2021 at 11:06 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    If the stronger battery "fixed" this for you, that's great news. However, I suspect you'll be back here again with the same issue.
    One thing I want to clarify is the people suggesting putting new contacts into the starter, that will absolutely fix the problem. However, it's likely not needed and you can fix the issue with a piece of fine sand paper. I wrote a how to thread on this topic about 10 years ago. Basically, the copper contacts get corroded over time and don't make a solid electrical connection when the engagement pin drops onto them. This happened to me when I got stuck in deep water for a long time. All you need to do is take the starter apart, sand down the contacts till they're shiny again, reinstall, and you're good to go.
    PS: I still run this exact same starter 10 years and probably 150k miles later.
    https://www.tacomaworld.com/threads/how-to-rebuild-the-tacoma-starter-motor.200964/
    ohcaltexscar and Jimmyh like this.
  7. Jul 12, 2021 at 8:27 AM
    amansker
    Andy
    San Diego, CA
    And thanks to everyone that commented - very helpful. If the starter must be rebuilt within a year I'll revisit and post.
  8. Aug 23, 2021 at 3:25 PM
    amansker
    Andy
    San Diego, CA
    And six weeks later...click click. Dead in the water in my driveway. Battery good. Replaced the starter and all is good. Thanks for all the help.
    Jimmyh likes this.
