Need help diagnosing 4wd indicator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CroResident, Apr 19, 2016.
  1. Apr 19, 2016 at 8:55 AM
    CroResident
    CroResident [OP] Well-Known Member
    Nick B
    Opelousas, Louisiana
    2015 4X4 DCSB
    6" Zone lift 35x12.50 Super Swampers
    ive been struggling with the flashy light indicator.
    been through all the hassle of pulling the actuator and soldered the connections and it worked fine for about two months
    two days ago i was hauling a 6x12 trailer loaded down with logs through a muddy field.
    i locked it in 4hi. it went into 4wd perfectly and i made it across the field just fine.
    i left the truck in 4hi and turned the truck off to unload all the logs.
    i get back in and crank it up; low and behold, the green 4wd indicator light starts flashing. (here we go again)
    New Issue:
    Now, it seems that even when i switch back to 2hi, the light still flashes and the truck stays in 4wd (i got under the truck and checked the front drive shaft to make sure...definitely stuck in 4wd)
    i was able to get it back in 2wd by turning the dial to 2hi and turning off the truck, and then cranking it right back up again. (light stops flashing when i do this)
    now, whenever i want to engage 4wd, i have to turn the dial to 4hi, then turn off the truck and turn it back on again.
    even though it engages into 4hi, the indicator light continues to flash, which disables me from getting it into 4Lo.
    i am sick and tired of dealing with this. :frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty:
    can someone please give me some info? i would greatly appreciate the help more than you can imagine.:help:
  2. Apr 19, 2016 at 9:08 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Sounds like accuator / solenoid issue. It's getting juice but maybe not enough to hold in check for 4x operation or maybe a stuck solenoid, I hate electrical shit haha...
  3. Apr 19, 2016 at 9:48 AM
    CroResident
    Nick B
    2015 4X4 DCSB
    man i tell you what that electrical stuff is my worst nightmare. im fine with nuts and bolts but wires?? oh no sir not for me haha.
    how would i go about checking for a stuck solenoid?
