Need help diagnosing an issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bunst, Mar 4, 2022.
  1. Mar 4, 2022 at 5:16 PM
    Bunst
    Bunst [OP] Member
    2017 TRD Offroad
    I have a 2017 v6 access cab with 97k km on the odometer. I have not done any mods, the truck runs stock-size tires and I have owned it since new. I had just completed a long road trip 1000km+.
    I was starting the truck after it had sat for a few days and it turned over but didn't start. After a few tries, it kind of sputtered to life. I have been having some strange problems ever since. It seems to rough start 1/5 times. I took the truck to Toyota dealer after about a month hoping something else would pop up making the issue easier to diagnose but they said nothing was wrong. I've run 2 tanks of seafoam through it hoping it was a clogged injector but it didn't seem to do much.
    A few of the things I've noticed.
    ROUGH idle. Jumps around and flutters while idling.
    30%+ reduction in fuel economy.
    No low-end power makes it hard to hold cruising gears
    Already present gear hunting is much worse
    There is a new clicking sound coming from the driver's side of the engine.
    I know this sounds funny but the engine just sounds different. Almost like a diesel idling with an uneven lope.
    I am planning on changing the spark plugs in a week. I'm going to put a bore camera down the plug holes and see if one of the injectors is leaking.
    Does anyone have any idea of what this could be or what next steps I could take to figure out what's going on?
    If I get some suggestions I'll try and keep this thread updated when I'm able to fix the issue.
  2. Mar 4, 2022 at 5:21 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Spark plugs would be a good start
    RustyGreen, Bunst[OP] and Bishop84 like this.
  3. Mar 4, 2022 at 5:23 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    X2, and check your battery and its connections.
    RustyGreen and Bunst[OP] like this.
  4. Mar 4, 2022 at 5:37 PM
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Just out of curiosity, on your trip did you continuously try to squeeze as much gas in the tank as possible after the pump clicked off when filling the tank?
    Bunst[OP] and bulalo like this.
  5. Mar 4, 2022 at 6:26 PM
    Bunst
    Bunst [OP] Member
    2017 TRD Offroad
    Checked the battery and the alternator charging. Doesn't seem to be out of the ordinary.
    Mark77[QUOTED] likes this.
  6. Mar 4, 2022 at 6:27 PM
    Bunst
    Bunst [OP] Member
    2017 TRD Offroad
    No I just fill until it clicks.
  7. Mar 4, 2022 at 6:31 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    It sounds like fuel pressure or spark related. I am surprised there are no codes and the dealership released it back scratching their heads.
  8. Mar 4, 2022 at 6:32 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    This thread may help:
    https://www.tacomaworld.com/threads/2017-tacoma-ticking-sound.466301/
    Specifically this post: https://www.tacomaworld.com/threads/2017-tacoma-ticking-sound.466301/#post-13968605
    " said its the spring on the injectors due to the high pressure and they all make this racket."
    This site may help too:
    https://www.toyoheadquarters.com/threads/2016-2017-tacoma-with-ticking-noise-3-5l.480/
    The ticking sound is a result of the self-cleaning direct fuel injection systems activation and is a normal characteristic of normal system operation. No repair is necessary to remedy this condition.
  9. Mar 4, 2022 at 7:46 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Lets hope it's not a valve issue.
    Have you had the fuel pump recall done? Have you, or a dealer, replaced the crankshaft position sensor?
    Barring those major items, I'd check the battery, clean the throttle body and mass air flow sensor, and then replace the spark plugs.
    Bunst[OP] likes this.
  10. Mar 4, 2022 at 8:02 PM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
  11. Mar 4, 2022 at 8:32 PM
    Bunst
    Bunst [OP] Member
    2017 TRD Offroad
    I have a crankshaft position sensor on order as it's not an expensive part. My vehicle isn't listed as requiring a recall but that doesn't mean the issue isn't present. Ill clean the MAF and the TB when changing the plugs.
    I'll add the fuel pump to the list.
    I'm hesitant to jump to valves as I don't have the smoke usually associated with bad valve seals.
    Any other ideas?
  12. Mar 4, 2022 at 8:33 PM
    roboturner
    Colorado
    Plugs and clean before ordering any expensive parts
    you may take a very long screwdriver or metal post and hold your ear to the end while placing the tip on the various pumps and pulleys in the bay to try and zero in on where the sound is coming from - how I found my Fd buzzing PS pump
  13. Mar 21, 2022 at 6:24 AM
    Bunst
    Bunst [OP] Member
    2017 TRD Offroad
    So I changed the plugs this weekend and I can't believe how much better the truck drives! All of the strange noises seem to have resolved themselves. I did bore scope all of the cylinders and found they were pretty sooty and the plugs smelled like gas. They were not fouled with oil. Seems like the problem was just old plugs after all. Will probably change them a bit sooner next time haha.
    Thanks, everyone for your suggestions. Glad this was an easy fix.
    whatstcp, mtip, Big tall dave and 5 others like this.
  14. Mar 21, 2022 at 6:28 AM
    coma toy
    coma toy Off Road Taco
    Great news!
    Now go get yourself some nice aggressive oversized tires, and enjoy the fuck outta your Off Road! :smokertransformer:
  15. Mar 21, 2022 at 7:02 AM
    Fredk
    Fredk Well-Known Member
    Fred
    Dark grey 2020
    o2 sensors can cause that problem. Gas smell and poor mileage.
  16. Mar 21, 2022 at 9:08 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  17. Mar 21, 2022 at 9:31 AM
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2025 SR 4X4 DCSB
    sweet, glad you go it straightened out. Do you ever put your foot to the floor? I give mine the good ole Italian tune up every day on the interstate on-ramps
  18. Mar 21, 2022 at 9:52 AM
    Bunst
    Bunst [OP] Member
    2017 TRD Offroad
    All the time hahaha. Gotta take it to 11 every once and a while.
  19. Mar 22, 2022 at 1:56 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    What plugs did you go with and how difficult was the shange? Happy it worked out for you.
  20. Mar 22, 2022 at 7:09 AM
    Bunst
    Bunst [OP] Member
    2017 TRD Offroad
    I ordered the denso OEM plugs. I've heard of people going with NGK plugs but I don't think it would be worth the money.
    As for the installation, it took me about 4 hours to do. A lot of manuals tell you to pull the manifold because it's difficult to access the coils. Do not listen. They are lying. Leave the manifold in place and unplug and wiggle the wires around until you can extract the coils and plugs. Treat yourself to a good set of extensions that have the flex ends and you'll be fine. If you are curious you can grab a $20 borescope and stick it down the cylinder to get an idea of what's going on in there. Don't forget the dielectric grease.
    VaToy[QUOTED] and roboturner like this.
