need help diagnosing for a friend
Discussion in 'General Automotive' started by fireturk41, Nov 14, 2010.
  1. Nov 14, 2010 at 9:01 AM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i work on this friends jeep alot, fortunately i dont have very much experiance with engine diagnosis. He is burning about a quart of oil a week in his straight 6, this process hastens in 4wd, i have no idea what it could be, valve cover gasket was replaced 10k miles ago
  2. Nov 14, 2010 at 9:50 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    Valve cover torqued back on properly?
    Blow-by?
    Are you positive that it's burning instead of leaking?
  3. Nov 14, 2010 at 10:00 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    are you burning it.....
    bad rings mabye
  4. Nov 14, 2010 at 10:09 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    the 4.2 carbed. I think i was reading something about it in the jeep forums yesterday
  5. Nov 14, 2010 at 10:25 AM
    cc350
    cc350 Retired Member
    If he's burning oil, then his rings are worn or bad valve seals. Could be a bore and piston job or a valve job.
  6. Nov 14, 2010 at 6:50 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    any idea why oil usage would increase in 4wd?
  7. Nov 14, 2010 at 8:07 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Would think so.
    Leaking a Qt a week there would hopefully be signs of leakage on the ground, at least coating the undercarriage. Might as well see what the coolant looks like also.
    Engine is working harder in 4x4. Same reason gas mileage goes down in 4x4.
  8. Nov 14, 2010 at 8:20 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    ill pop open his hood at school tomorrow and check for leaks, thanks for the input ill keep yall posted
