Need help diagnosing noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by M1ldlyAdequate, Aug 9, 2022.
  1. Aug 9, 2022 at 3:53 PM
    M1ldlyAdequate
    M1ldlyAdequate [OP] Member
    Karsten
    2011 Tacoma TRD Sport V6 4WD LB
    Over the hood pod lights and hard tri-fold tonneau cover
    I'm trying to figure out a sound that my truck is making and need to know as soon as possible.
    The sound is a ticking noise that seems to be coming from the driver side under the hood and/or behind the driver side wheel. The noise only happens under two conditions. 1) when the accelerator pedal is being pressed and the engine is running at ~1,500 rpm and above. 2) occasionally on a cold start the noise happens for approximately 15-30 seconds when idling.
    The noise increases in speed and volume as the engine's rpms increase, but immediately stops when I take my foot off of the accelerator. The noise does not happen when idling, except for the previously mentioned cold start or when the transmission is in neutral.
    https://youtu.be/hbWj5oqq664
    I've attached a link to a video of the noise, that I recorded. In the attached video, the noise is subtle and sounds like background noise compared to the wind noise, but can still be heard. The first half of the video is recorded from outside the driver side window and the second half is recorded from around the pedals on the driver side.
  2. Aug 9, 2022 at 3:54 PM
    KingOfTheNorth
    KingOfTheNorth Kum and Go King
    97 4runner
    All the mods
    taco tick...... (i didnt watch the video.)
    Judging from where you are hearing it from thats the taco tick. It sounds a bit different tho. Did you just do a oil change by any chance?
  3. Aug 9, 2022 at 3:55 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Welcome to TW
  4. Aug 9, 2022 at 3:56 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Sounds like a manifold leak to me..and based off your description it would be the driver side manifold.
    Dm93 likes this.
  5. Aug 9, 2022 at 4:03 PM
    M1ldlyAdequate
    Karsten
    About 2k miles ago
  6. Aug 9, 2022 at 4:17 PM
    KingOfTheNorth
    97 4runner
    All the mods
    Could be you are low on oil. Check there for starters. Otherwise pop the hood and start the motor and get a new video and see if you can pinpoint the sound that way. For future reference I do 6qts of oil on my changes and gets rid of the ticking noise. That is if this is the actual culprit of your sound.
  7. Aug 9, 2022 at 4:39 PM
    2jyoda
    2jyoda Well-Known Member
    Stevie
    Chandler az
    2021 Super White SR Taco 3.5 V6
    SDHQ ABS Guards, AC Drain mod lol. Bed Mat and Bed lights.
    lifter??
  8. Aug 9, 2022 at 4:41 PM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Exhaust leak - Check all the pipe junctions.
    KingOfTheNorth and Strictlytoyz like this.
  9. Aug 9, 2022 at 5:00 PM
    Waasheem
    Waasheem
    2007 xrunner
    You could try a long wooden dowel. Be careful of moving parts. Touch the dowel to where the noise could possibly be coming from. You might be able to sorta feel the vibration the noise is making.
  10. Aug 9, 2022 at 5:26 PM
    M1ldlyAdequate
    Karsten
    I checked the oil this morning and it's still full. Last time I changed it I put 5.8 quarts in.
  11. Aug 10, 2022 at 7:19 AM
    KingOfTheNorth
    97 4runner
    All the mods
    Well then its not the easy fix. I would start checking what the others said with the manifold and trying to pin point exactly where the noise is coming from with the hood up and the engine running.
  12. Sep 10, 2022 at 12:37 PM
    Swb_05
    Swb_05 Member
    Casey
    2005 Speedway Blue TRD OR
    @M1ldyAdequate, did you get this problem resolved? My truck just started doing the same thing on our last wheeling trip, only passenger side. Gonna check a few things mentioned above, but just curious what you got figured out.
    Thanks
