Need help diagnosing oil leak.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NicholsTacoma06, Dec 22, 2023.
  1. Dec 22, 2023 at 1:37 PM
    NicholsTacoma06
    NicholsTacoma06 [OP] New Member
    2008 Pearl Red Tacoma
    My 08 tacoma has the 4.0L V6 with 105,000 miles. I just started noticing an oil leak which has sprayed oil everywhere under the engine making it very difficult to find where the source is. It’s definitely not valve gasket (No oil on top end, just near bottom.) There is an excess of build up on the crossmember directly under the engine. Any ideas?
  2. Dec 22, 2023 at 2:01 PM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    If it's engine oil then a few places to check - Front crank seal, timing cover seal (specifically in the area behind the power steering pump), and the little timing chain access cover on the passenger side of the water pump.
  3. Dec 22, 2023 at 8:10 PM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    Clean entire area well. The spray on degreaser works pretty well. Then star truck and idle for as long as it takes for the oil to show, then trace to source. The air moving around while driving is what makes the mess. May need to up the rpm’s to make it leak sometimes.
  4. Dec 23, 2023 at 6:10 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Go to an autoparts store and get the $6 bottle of uv dye, and a cheap uv flashlight. You'll find it easy.
  5. Dec 23, 2023 at 6:55 PM
    TacoTuesday1
    SD CA
    Clean. Spray gold bond. Re-evaluate.
    Oil goes down from gravity. It goes backward due to driving forward and fan blowing back.
    and drips over stuff giving there's no straight path
    meaning if it has been doing this for a while, it's too late to catch it fresh and see exactly where it's coming from
    since it's had time to spread out over everything. To look like everything is leaking.
    So clean it. And find specifically where it's coming from, after it is cleaned.
