need help diagnosing starting issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bamabrad1970, Feb 8, 2018.
  1. Feb 8, 2018 at 7:58 AM
    bamabrad1970
    bamabrad1970 [OP] Member
    2016 Tacoma sport. Battery specs below. I've noticed this issue this winter when I have my seat warmers on full blast on my way to work. I usually have the car idle in the parking lot for a few min before turning it off before I go in. The seat warmers on the whole time. Also have my headlights on auto so they are on, along with the heater too. And I do usually eat lunch in my car but I just bear the cold because I don't want to waste gas. So it's never turned on. But anyway this winter when I've gotten into the car to go home after work when I've had the seat warmers on in the morning, it has been starting sluggishly and then yesterday it didn't start at all. I just had my 15000 serivce done and the battery checked out. Any ideas what the problem could be? Is this battery not very powerful maybe? Ever since I've had the truck it starts sluggishly if I've turned on the radio for 30 min or so without it running. Once it starts to get a little cooler it'll start sluggishly after 15 min of that. The first time I went too long and had to jump it I took it to the dealer thinking I had a bad battery and they said it was fine and I shouldn't run the radio more than 15 min without starting the engine for a bit. Anyway, any advice would be appreciated. I'm hoping that even though maybe this battery isn't bad per se that maybe it just kind of sucks?
    Part #: 28800-03044
    Made by: Johnson ControlsBattery Group, Inc. USA
    Distributed by : ToyotaMotor Manufacturing
    CCA: 582 amps
    Reserve Capacity: 125 minutes
    Group: 24F
    Recycle: Pb
  2. Feb 8, 2018 at 9:16 AM
    COMTBSKI84
    COMTBSKI84 New Member
    2017 Blazing Blue Tacoma
    Following. I have the same issue with my 2017 Sport no seat heaters for me though. Happens while the truck is garaged and outside.
  3. Feb 8, 2018 at 9:19 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I cannot help you with your battery issue but you realize you only burn between 1/3 and 1/2 gallon an HOUR when idling only? That's like .80 cents an hour.
  4. Feb 8, 2018 at 9:23 AM
    bamabrad1970
    yeah, I don't know any particulars of the amount used....but you are right I probably shouldn't be sweating that. Ever since I've gotten this truck though it's made me kind of anal about watching the gas mileage meter and I hate watching that go down sitting in a running car at lunch. Ha. I know it's dumb.
    shakerhood and hiPSI[QUOTED] like this.
  5. Feb 8, 2018 at 9:43 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    A few bucks in gas beats a dead battery when it's freezing cold out though.
    hiPSI likes this.
  6. Feb 8, 2018 at 9:48 AM
    bamabrad1970
    No doubt, it does for sure. This isn't my problem in this thread though. I already learned that lesson.
    shakerhood likes this.
  7. Feb 8, 2018 at 10:19 AM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    If it's the original battery it's probably time for a new one. They seem to make these things to last just over the 36k warranty, but cold weather probably accelerates that. Try this - Have a friend give you a jump from their running vehicle. If it starts easily you know it's probably the battery. I'd have them check my charging system when it was replaced as well.
  8. Feb 8, 2018 at 10:21 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    That's your problem.
    If you are going to sit in your truck longer than ten minutes with anything on, start it.
    I came home one evening planning on going back to work and left my truck running. (This was years ago and it was a gas guzzling GMC.) And then I changed my mind. The next morning I walked out to a nicely warmed truck that was still running. Sheeeeesh. :eek:
    The gas gauge hadn't moved.
    SB
  9. Feb 8, 2018 at 10:22 AM
    bamabrad1970
    It started up really fast yesterday when it was jumped. The problem is the battery doesn't test as it's bad. I'm just wondering if my issues is because it's a little low on CCAs possibly.
  10. Feb 8, 2018 at 10:25 AM
    ksj
    Pacific NW
    265/70-17 KO2
    I just noticed you're using the seat warmers without it running. Sorry, read through to fast. Those seat warmers chew through battery life. You really need to run the engine while those things are on. You're battery is probably fine, but if you want to use those warmers while it's off you'll need a significant upgrade. How long is your commute? Is it long enough to recharge the battery?
    Edit - Your alternator doesn't really charge the battery much at idle, but the battery won't discharge from accessory use while idling. If you have a short commute and don't get the engine into a good charging range (2k+) long enough the battery will discharge over time.
  11. Feb 8, 2018 at 10:32 AM
    bamabrad1970
    no I’m not using them with the engine off.... I get to work and the engine is idling for a few min before I turn it off and go in. I only have sluggish starts or not starting at all like yesterday in that scenario. Seats on high...then few min of idling then turned off....8 hours later it stuggles to start. Usually temp in 30s or lower.
  12. Feb 8, 2018 at 10:35 AM
    Trachito
    Trachito Well-Known Member
    New Orleans
    I've measured the voltage at idle and it was enough to charge the battery. Short distances however can kill a battery because it doesn't charge long enough.
  13. Feb 8, 2018 at 10:41 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Which battery is larger, 24 or 27, I forgot. The battery may be undersized for what you're doing to it, but it's not undersized for the truck. Also in winter, the battery will be more sluggish than when it's warmer, this is normal. Conclusion, your battery is fine, but if you continue to discharge it without charging it, then you're going to have the sand problem again. Especially in colder weather.
  14. Feb 8, 2018 at 10:43 AM
    shakerhood
    Southern Ohio
    27F is larger than the 24F, in the 2nd Gen they gave you the larger 27F when you got the Tow Package.
  15. Feb 8, 2018 at 10:51 AM
    sirhc91
    sirhc91 Well-Known Member
    San Diego CA
    2018 Tacoma TRD OR 4X4
    holy cow how did someone not steal that thing, crazy
  16. Feb 8, 2018 at 10:55 AM
    ksj
    Pacific NW
    265/70-17 KO2
    Yes, it will produce voltage at idle, but not the amps needed to charge a discharged battery. You would need to check the alternators amperage output to test it at idle and under load to see the difference. This is a pretty good description and shows ways to test.
  17. Feb 8, 2018 at 10:57 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    You said you had the battery "checked". I'd assume that they filled it with distilled H2O at that time also.
    I just checked my 2016's battery this fall (2yrs old) and it took about a cup of H2O... They will "off gas" and lose water over time.... Gotta keep it full.
    Good thing to check guys, if you haven't already..!
    2 Yr old battery should not normally be weak unless abused or unmaintained..!! :thumbsup:
  18. Feb 8, 2018 at 10:57 AM
    Sagebrush
    Gens 1, 2, 3, and 4
    Because I live in the middle of nowhere. It helps.
    SB
  19. Feb 8, 2018 at 11:45 AM
    bamabrad1970
    Yeah, I'm thinking it's just a little undersized since I only have issues when running the seat warmers at full. I wonder if I had the 27 if none of this would be happening. I guess I probably do need the dealership to check the alternator before it runs out of warranty though! Is there an official recommended battery? Doesn't say a thing about that in the owners manual which is really odd to me. But this battery like my original posts says is 582 CCAs and I don't see too many people recommending any that low when I do a search....
  20. Feb 8, 2018 at 11:55 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Get the dealer to drop in a 27 on their dime since you're having BS issues and it shouldve came with a higher cap battery to handle the load of extra electronics.
