need help diagnosing starting issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bamabrad1970, Feb 8, 2018.
  1. Feb 8, 2018 at 12:03 PM
    1tacomaluvr
    1tacomaluvr Well-Known Member
    '17 Inferno OR DCSB
    I keep a battery tender on my battery whenever it is at the house, always starts right up and my alternate cars battery is five years old with no issues, knock on wood! Not a battery charger, must be a "maintainer". Maintainer will not over charge! Good luck.
  2. Feb 8, 2018 at 12:19 PM
    bamabrad1970
    bamabrad1970 [OP] Member
    yep, I think that's what I'm going to have to do
  3. Feb 8, 2018 at 1:20 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think you need a Battery Tray from a 2nd Gen V6 with Tow Package to fit the 27F correctly, otherwise the battery will overhang the tray.
  4. Feb 8, 2018 at 1:22 PM
    bamabrad1970
    dang....maybe I just need more CCAs then
    over60 and shakerhood[QUOTED] like this.
  5. Feb 8, 2018 at 1:24 PM
    shakerhood
    Southern Ohio
    The Northstar 24F that guys talk about on this Forum all the time has quite a bit more CCA
  6. Feb 8, 2018 at 4:35 PM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    Just keep it idling when you're using power. That's what the electrical system is designed to do.
    Starter batteries are made to dump lots of power fast. Turn the engine over. They are not made to sit and discharge. Deep cycle batteries are... but they are not made to start an engine so don't think that's the fix.
    I wish you luck trying to convince the dealership you need a bigger battery (and bigger tray) because Toyota has a design flaw.
    In the firearms world, this would be called an operator induced malfunction.
    SB o_O :D
    P.S. If you drew the battery down to the point it was dead, you probably do need a new battery.
    shakerhood likes this.
  7. Feb 8, 2018 at 5:19 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Did they load test it, or just check voltage? My bother-in-laws 16 tundra 9000 miles had a one cell bad, dealer replaced His read 12.9 volts when they checked it after he got there. Then he said aren't you going to load test it? They did and after test 8.3 volts wouldn't start.
  8. Feb 8, 2018 at 6:27 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    This...
    Hydrometer test?
    What do your terminals look like?
