Need Help: F/R Wheel Bearing Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yodas-Taco2009, Sep 13, 2020.
  1. Sep 13, 2020 at 1:27 PM
    Yodas-Taco2009
    Yodas-Taco2009 [OP] New Member
    Brian
    Nebraska
    ‘09 Tacoma AC - 4x4, 4.0L
    I have a 09 Tacoma access and it needs the front right wheel bearing replaced. I’m more of a novice of fixing things, and I have a couple questions about it.
    I got quoted $621 for the replacement of my Front passenger side wheel bearing. I looked into what it takes to do, but how long does it usually take to do? Are there any struggle points? Would it be better to get it pre-assembled?
  2. Sep 13, 2020 at 1:44 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    I had one side growling, so I went ahead and replaced both sides with pre-made assemblies. It's pretty easy.
  3. Sep 13, 2020 at 2:10 PM
    YotaFAB
    YotaFAB Well-Known Member
    I did it with the pre-assembled units when I put my lift on. easiest part of the install.
  4. Sep 13, 2020 at 3:34 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    OP, just beware. There are lots of sub-standard grade replacement bearings and hub / bearing assemblies available out there. The price you were quoted is probably for a Toyota OEM part and that's why it's expensive. There are far cheaper options out there, but you get what you pay for. If you're planning on keeping your truck for a while, put OEM in. If not, roll the dice with the cheap stuff.
    Mdean1107 and Yodas-Taco2009[OP] like this.
  5. Sep 13, 2020 at 3:37 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    My mechanic quoted me $300 per side for pre assembled hubs and $200 for labor per side. $1k both sides OTD.
    It was a little pricey I think. If it was DIY, I could have saved $400 possibly.
    There are a few vendors here that make pre assembled hubs.
  6. Sep 14, 2020 at 5:19 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    You should ask him for the pre-assembled hubs, and do the rest yourself.
  7. Sep 14, 2020 at 7:03 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Napa had the bearing/hub preassembled with O ring and CV seal on the back of the spindle for around 200.
    If you've got tools, the only odd ball is a 35mm socket for the CV nut.
    Take the tire off, dust cap, put the tire back on and preferably with someone on the brakes, break the CV nut loose. Put it back up on a jack stand or 2 and let the fun begin....
    Remove the caliper, rotor. Then you can get to the 4 bolts securing the bearing to the spindle. Use the back of the wheel studs to pull the bearing out as you unbolt the bearing.
    To replace the seal that mates with the CV, remove the tie rod link from from the spindle and the 2 bolts on either side of the lower ball joint. The spindle will now swing forward to make replacing the seal much easier.
    Replacing that seal can be a bitch unless you make a tool with a 3" PVC female adapter and a threaded plug with a square stud for a wrench. The seal fits perfectly on it, and with one wrap of tape to hold it on, it'll pop right on the spindle with a couple taps of a hammer.
    First time replacing with no guidance, took about 3 hours. I think the last one I did took 90 minutes.
    Yodas-Taco2009[OP] likes this.
  8. Sep 14, 2020 at 7:08 AM
    vermont
    vermont Well-Known Member
  9. Sep 14, 2020 at 7:10 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Spend the extra $ for quality parts and do BOTH sides; if one is failing, the other will likely follow soon.
  10. Sep 14, 2020 at 7:26 AM
    Larzzzz
    Larry
    MA
    ^^^^what he said
  11. Oct 3, 2020 at 5:29 PM
    Ibocnet
    Ibocnet Well-Known Member
    Rich
    2010 TRD Sport DCLB
    Toytec 3" front lift, OME 3" rear lift, ARE MX Cap, Budbuilt Armor
    Any Recommendation other that Toyota? Or any to stay away from. I want to buy quality. Toyota seems quite expensive. Are they worth it?
  12. Oct 3, 2020 at 8:29 PM
    Muddinfun
    Muddinfun Well-Known Member
    BrianT23 and dk_crew like this.
  13. Oct 3, 2020 at 8:45 PM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
  14. Oct 4, 2020 at 3:57 AM
    Too Stroked
    Tom
    Remember, that video is for a 2 wheel drive Tacoma.
  15. Oct 4, 2020 at 4:56 AM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    I replaced both my fronts about 6 months ago with the beck/arnley hub assembly from rock auto , made a big difference in noise and vibrations , did 2 long road trips and no problems so far. Seems like a well built unit but time will tell. Good luck keep us posted.
  16. Oct 4, 2020 at 5:10 AM
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    Good catch. If I recall, the only difference is the 35mm nut that also needs to be torqued back to (I think) 173.
  17. Oct 4, 2020 at 7:05 AM
    Ibocnet
    Rich
    2010 TRD Sport DCLB
  18. Oct 4, 2020 at 7:10 AM
    Muddinfun
    Yes, they’re complete units. He changed the wording after 1 guy, out of hundreds sold, had a problem.
    Ibocnet[QUOTED] likes this.
  19. Oct 4, 2020 at 8:44 AM
    westport toyota
    westport toyota Well-Known Member
    I've done it twice. I wouldn't use the word easy
    Ibocnet likes this.
  20. Oct 4, 2020 at 9:35 AM
    Ibocnet
    Rich
    2010 TRD Sport DCLB
    Why twice?. How many likes should I expect to get out of them? I don't even know that I need them. I definitely need to replace the rotors because I know I overheated them going downhill in Colorado, I replaced the pads and they still shake. $148K on originals I figure it might pay to replace them. Now I'm not sure because of the cost. Rotors are pretty cheap.
