Need help fast!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by kingston73, Aug 8, 2009.
  1. Aug 8, 2009 at 5:56 PM
    kingston73
    kingston73 [OP] Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    Ok, so here's my situation: First, earlier this week drove to the gas station, the temp gauge started moving toward red. When I stopped my coolant was almost gone, filling the rad and the overflow took close to 3/4 of a bottle of 50/50 coolant. Drove it a little the next couple days, the coolant didn't obviously leak out, the level stayed the same, and no other symptoms so I thought things would be ok. Then, today, driving on the interstate from MA to VA, keeping speeds of 75-80. Drove no problems for about 3-4 hours, then suddenly something started "chirping" and I started losing power. No acceleration at all, I could maintain speed on a flat but no power going uphill. When I stopped and checked, coolant level was still normal, but I was down about a 1/4 quart of oil. The sound was almost like a slipping belt, a "chirping" sound that I couldn't pin point. It's in the shop my parents use, I have no tools with me and no idea what to expect. The check engine light came on while I was driving over to the shop, it flashed a couple times and then stayed on constant. The only other "weird" symptom was for a few minutes things went back to normal, the chirping went away and the power came back, but then the chirping came back and the power dipped immediately. Ideas??? I just want to know what to expect before the shop tells me something, I don't entirely trust mechanics I don't know.
  2. Aug 8, 2009 at 6:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW!
    Sounds like maybe your water pumps is siezing up.
  3. Aug 8, 2009 at 6:03 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Something's siezing up. Maybe the AC compressor or the water pump?
  4. Aug 8, 2009 at 6:59 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Run the OBDll on it. Its free at autozone and have them print out the code for you. Let us know what the mechanic tells you good luck. Oh yea and welcome to tacomaworld where all of your allowance money is going to be spent :D
  5. Aug 8, 2009 at 7:07 PM
    kingston73
    eastern MA
    09 SR5 4.0L 4x4
    Thanks for the welcome. I just found you guys, I just typed in "tacoma forums" into google to get some feedback into what this might be. The shop I took it to is actually open sundays, so they told me they'd call me when they diagnosed it. My wife and I are 500 miles from home, no tools or shop manual, so I'm kinda at the mercy of whatever the mechanic tells me. I just like to be informed before I have somebody I don't know tell me I need to give them a thousand dollars. If it's water pump replacement, what's a typical price I should expect? And would a failing water pump throw a check engine code right away? It took about an hour of driving before the check engine light came on. In an ideal world, I would have stopped driving it as soon as I started hearing the chirp, but the temp gauge stayed centered, right at 1/2, and I knew I had oil so I didn't get it towed.
  6. Aug 8, 2009 at 7:13 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Sounds like a water pump issue to me....you ARE losing coolant somewhere. Look around the pump and see if there is any evidence of leakage.....possibly a faulty thermostat causing the on again, off again readings.
  7. Aug 8, 2009 at 7:50 PM
    Brunes
    Brunes abides.
    Rotorhead
    +1 for the water pump. About 100 bones to get the new part for an '01 and another couple 100 for labor...I'm not sure how hard a pump replacement is on those.
  8. Aug 8, 2009 at 7:52 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Where at you at in the world? Maybe a local member can help out.
  9. Aug 9, 2009 at 5:20 AM
    kingston73
    eastern MA
    09 SR5 4.0L 4x4
    Right now I'm in Falls Church, VA. I appreciate the offer for local help, but we need to get this fixed in the next day or 2. Why can't these things ever break in the driveway?
  10. Aug 9, 2009 at 5:27 AM
    JDMcQ
    I wish I could help. I wish you luck.
  11. Aug 9, 2009 at 7:32 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    agreed on both statements.
  12. Aug 9, 2009 at 7:41 AM
    kingston73
    eastern MA
    09 SR5 4.0L 4x4
    Well, got the call from the mechanic. 2 different problems, he said neither one was related.
    The coolant issue: the radiator is leaking, so they are going to replace rad, hoses, and thermostat. Complete flush of system and then refill.
    The power loss issue: #3 coil misfired, so I was basically running on 3 cylinders. Have any of you ever had that happen? That's what caused my check engine light, I've never heard of that. The truck only has about 150,000 on it.
    Total price: $960-970
    I'm not getting gouged here, am I?
  13. Aug 9, 2009 at 7:45 AM
    07trd4x4
    07trd4x4 Well-Known Member
    Greg
    Truckee/Sacramento CA
    LX570
    i was say.... that is a pretty fair price... but what do i know i am in CALI... that sux....sorry to hear that bro... welcome to TW.. btw and good luck!!!
  14. Aug 9, 2009 at 7:48 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Did he say why the rad was leaking? Did it deteriorate? Puncture? Reminder: AlWAYS USE DISTILLED WATER IN YOUR SYSTEM.
  15. Aug 9, 2009 at 7:52 AM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    That does make sense now that he said that about the coil missfiring. It would definately cause a loss of power and even some over heating issues. If it were an old chevy you could get it replaced for less then $50. Oh times have changed.
    Does anybody know how much one of those coils costs. If the parts are cheap and the labor is alot I have all of my tools and am in Colonial Heights near Richmond. I could give you a hand replacing it.
  16. Aug 9, 2009 at 7:55 AM
    07trd4x4
    Greg
    LX570
    way to be there for a toyota owner!!!!!! love it!!!
    :infantry: TW to the rescue
  17. Aug 9, 2009 at 7:55 AM
    jeremiekc
    Jeremie
    Vilseck, Germany
    Oops! Sorry about that I didnt realize Falls Church was a two hour drive north. I am just here temporary.
  18. Aug 9, 2009 at 7:57 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Most of his mechanic's expense is going to be related to the rad stuff. Bummer. But at 150K miles, shit happens.
  19. Aug 9, 2009 at 8:00 AM
    jeremiekc
    Jeremie
    Vilseck, Germany
    I bet it is the price of the radiator they cant be cheap. In the old days I would say just break a couple of cigerettes or put some bars leak in it and call it good. With all of the new sensors and stuff they have on them now days I dont think you can do that any more.
  20. Aug 9, 2009 at 8:07 AM
    kingston73
    eastern MA
    09 SR5 4.0L 4x4
    Wow, thanks for all the replies! I think this is my new favorite truck forum. The mechanic didn't say exactly why/how the rad was leaking, he just said if the thermostat got stuck that could have caused a build-up of pressure. I'm wondering why it was chirping though, forgot to ask the guy that. I'm also wondering if I should replace the water pump, even though the mechanic said it was fine. When do y'all generally replace it? I haven't looked at the manual yet, but is it a fairly decent DIY job? If it's fixed enough to drive back to MA, I can probably change the water pump myself.
