Need help fast
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flightcancled, May 16, 2010.
  1. May 16, 2010 at 9:15 AM
    flightcancled
    flightcancled [OP] Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Ok, I am installing my front 5100s and all was going well until I hit a major road block.
    I am at the point where I have compressed my spring, removed the top nut and now I am SOL. The washer under the nut won't budge! I tried everything I can think of including loosening the coil compressor to try and force it off. I am stuck. It won't come off even without the coil compressor on.
    What do I do?
  2. May 16, 2010 at 9:20 AM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Try PB blaster?
  3. May 16, 2010 at 9:24 AM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah...Some PB Blaster and a BFH. Just be careful.
  4. May 16, 2010 at 10:41 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I would definitely re-comepress the coil, and attempt to remove the washer without any force from the coil. Way too dangerous if it suddenly comes loose.
  5. May 16, 2010 at 11:04 AM
    xKazeex
    xKazeex Member
    San Diego
    '10 Prerunner TRD BC LB Magnetic gray
    Dremel it off.
  6. May 16, 2010 at 12:15 PM
    flightcancled
    That is a terrible idea.
    By the time I got back to the shop after posting this the coil sitting uncompressed had shot it off. The coil was in the same place with the strut 6" back and the washer assembly 18" in front of it. My GF was there and didn't even notice it happen. As I suspected there is barely any force on the spring at rest.
    Of course now I have worked my way to the other side and have the same issue all over again!:smash:
  7. May 17, 2010 at 2:40 AM
    flightcancled
    For future refference if this happens to someone else I wound up removing the compressors and giving the shock a solid wack into the concrete floor threaded end first. This was enough to kick loose the washer and spring. Seems scary, but the shock will only recoil about 1 foot off the ground.
  8. May 17, 2010 at 5:58 AM
    KPT
    09 Prerunner
    :eek: I would not have the balls to do that.
