Need help figuring out top speed issue (regearing)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Soupiy, Aug 22, 2023.
  1. Aug 22, 2023 at 10:12 AM
    Soupiy
    Soupiy [OP] Member
    Marcus
    Houston Texas
    2017 Tacoma TRD OR
    Leveling kit, 33s, exhaust, pedal commander, 5.29s, lights, cosmetic
    I regeared my truck not too long ago (5.29s). It has the issue of topping out at 86mph. My guess was the wheel sensors or something along those lines, are not working properly. I've heard a few things like recalibrating my speedo might fix it, I want to get it tuned but was told by my tuner that it wouldn't fix the top speed. Anyone know the solution?
  2. Aug 22, 2023 at 10:14 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome To TW.
    So ...what gear and RPM hits 86
  3. Aug 22, 2023 at 10:16 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    My truck topped out at 83 with 5.29's and 33's the one time I tested to see how fast it would go.
    For HondaGM, it is not at redline. When in 6th it is around 2800 rpm (IIRC).
    OP, were you not aware of this when you researched regearing?
    AFAIK, it can't be changed. Edit: Others point out that this can be changed with tuning software.
    HondaGM likes this.
  4. Aug 22, 2023 at 10:20 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i really don't know. but do you drive 86 mph often? seems excessive. mine's a bit stressful to drive over 75. it's not a sedan.
  5. Aug 22, 2023 at 10:21 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Welcome to tw.
    I'll be the one to throw the gas on the fire.
    Why would you want to go faster than 80 in a lifted/regeared truck?
  6. Aug 22, 2023 at 10:23 AM
    MR E30
    Michael
    Exactly.
  7. Aug 22, 2023 at 10:23 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    maybe they live in Texas. where everyone treats the roads like the Indy 500. even over here on the east coast, i see big truck with texas plates trying to go 90+ on the freeway passing everyone on the road :bikewheelie2:
    Junkhead, Chew, MR E30 and 1 other person like this.
  8. Aug 22, 2023 at 10:34 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    :anonymous:
    ... I stopped pushing 80 a while ago. Even on stock gears the Taco is not a happy camper when it's in the left lane. On the days I want to play Ricky Bobby I'll grab the fiancee's turbo hatch. Not in the truck though. I let the brodozers go ahead to exude their tailgating tiny pee pee energy onto someone else.
  9. Aug 22, 2023 at 10:34 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Everything is working properly. This happens with 5.29's based on how the truck limits. Not based on wheel speed but driveline speed.
    Junkhead and Chew like this.
  10. Aug 22, 2023 at 10:36 AM
    clg
    clg Well-Known Member
    2017 Off-road
    Not sure of the why, mine on 5.29s with bumpers and a plethora of other aerodynamic robbing parts got to 93 on 37s.
    As to the "why" question others are asking, because people with modified vehicles like to do things with them so why the hell not push it?
  11. Aug 22, 2023 at 10:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    There are many online top speed calculators. Simple math really as long as you don't forget any factors.
    Things like tire dia, trans ratio, rear ratio, RPM.
    However, they do not include CoD. Just moving in a vacumn.
    So, if any given vehicle can hit redline (fuel cut) in high gear, then the formula will be accurate. That's called gear limited.
    If you can't hit redline in high gear, it's generally drag limited. And the Tacoma is a brick for the most part.
    And is your 86 GPS verified? Mucking with your tires and gears has your speedo all unhappy.
    OTOH, the 'faux tune' from that Pedal Commander may be the problem. :rofl:
    Chew and HondaGM like this.
  12. Aug 22, 2023 at 10:39 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    You need a tune edit to change the axle ratio value to 5.29 so that the governor will be raised back to stock, or higher then. Your truck sees your new faster driveline speed and thinks you’re driving 110 mph or whatever it is (I don’t remember the exact stock governor value).
    Murd3rd and Soupiy[OP] like this.
  13. Aug 22, 2023 at 10:40 AM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    On a lot of the highways in Michigan the posted speed limit is 75mph. 85-86mph here is normal.
  14. Aug 22, 2023 at 10:40 AM
    ShimStack
    Ben
    NC
    You're limited to the same driveline speed, but 37's give you increased ground speed.
    This all depends on if folks are getting their reference speed from uncorrected speedo, corrected speedo, or gps.
    clg[QUOTED] and Soupiy[OP] like this.
  15. Aug 22, 2023 at 11:11 AM
    Soupiy
    Soupiy [OP] Member
    Marcus
    Houston Texas
    2017 Tacoma TRD OR
    it makes it into 6th, abour 3k rpm
  16. Aug 22, 2023 at 11:14 AM
    Soupiy
    Soupiy [OP] Member
    Marcus
    Houston Texas
    2017 Tacoma TRD OR
    I do mostly highway driving, I live in texas should say enough lol, i normally go around 80 and stay with the flow of traffic (alot of country highway).
    cryptolime[QUOTED] likes this.
  17. Aug 22, 2023 at 11:16 AM
    Soupiy
    Soupiy [OP] Member
    Marcus
    Houston Texas
    2017 Tacoma TRD OR
    I verified through gps. I do have a pedal commander so it might have something to do with it.
  18. Aug 22, 2023 at 11:18 AM
    Soupiy
    Soupiy [OP] Member
    Marcus
    Houston Texas
    2017 Tacoma TRD OR
    I've never had a problem going that fast in it, I've gotten up to 114 before letting off and there was no wobble or anything. I do alot of country highway driving so 80+ is the flow of traffic in Texas.
  19. Aug 22, 2023 at 11:18 AM
    Soupiy
    Soupiy [OP] Member
    Marcus
    Houston Texas
    2017 Tacoma TRD OR
    Lol you're completely right, 80mph to stay with the flow
  20. Aug 22, 2023 at 11:22 AM
    Soupiy
    Soupiy [OP] Member
    Marcus
    Houston Texas
    2017 Tacoma TRD OR
    Im on 33s. My tuner just recommended the Hyper tech or rough country speedo calibrator so i might try one of those. Very true, i'm not driving a modified truck to be normal lol
