Need help find truth about tire size!!
Discussion in 'Wheels & Tires' started by jdthorf, Jan 14, 2009.
  1. Jan 14, 2009 at 7:20 AM
    jdthorf
    jdthorf [OP] New Member
    Carleton Place, Ont. Canada
    2006 Tacoma 4x2 Access Cab
    I have an '06 Tacoma 4x2 Access Cab that is still financed and it has 215/R15's on it and I want BIGGER tires and they won't do it until my 100K warranty is up.I'm currently at 74K. What size can I take my tires up too on this thing - they will not giv me a straight answer. Thanks
  2. Jan 14, 2009 at 7:28 AM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    Who the hell is "they"?
    Welcome to TW BTW
  3. Jan 14, 2009 at 7:41 AM
    jdthorf
    Ya, I guess - who the hell are 'they' is right. They are the people at Toyota in Ottawa that service my truck where I bought it. Basically I'm tied in to them for servicing until my 100k comes up, and they won't THINK about allowing me to change tire size until 'they' are not liable, I guess. Thanks for the welcome!
  4. Jan 14, 2009 at 7:43 AM
    jdthorf
    Ya, the stealership:p
  5. Jan 14, 2009 at 7:44 AM
    jdthorf
    The 'Stealership' :p
    Thanks for the welcome.
  6. Jan 14, 2009 at 9:54 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Don't know what to tell you about the dealership man, that sucks. I'm running 30x9.5 Bridgestone Destination AT's on 15x8 wheels. There's a pic of my truck in my profile. I had to remove the metal blocks in the front wheel wells to get them to not rub. I don't know what the max tire size is you can go. I bought mine with these on it. I'm also guessing that you have a 5 lugger and not a Pre Runner.
    BTW, welcome to TW. There's lots of good info and advice on here.
  7. Jan 14, 2009 at 10:01 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    Welcome to TW..
    And they are full of SH!T. They just don't want to do the work. You can put any size of tires you want on your truck. It WILL NOT void your warranty regardless of what they say. They will have to prove that larger tires broke the item you are trying to have covered under warranty. You are protected by the Magnuson & Moss warranty act.
    http://en.wikipedia.org/wiki/Magnuson-Moss_Warranty_Act
    As far as tire size.. put on whatever size you want. :D
  8. Jan 14, 2009 at 10:03 AM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
  9. Jan 14, 2009 at 12:06 PM
    harshest
    Michigan
    05 PreRunner SR5
    I am going to say NO, but how would bigger tires void any warranty? Do they put any undo stress on any other suspension/steering parts?
  10. Jan 14, 2009 at 2:07 PM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Ah.. touche.. Canada. That law is US specific. Didn't notice that.. hmmm... I would hope they had something similar to protect the owners.
  11. Jan 14, 2009 at 3:22 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    there is a similar law in canada that the failure has to be proven to be the cause of a modification for them not to void.
