Need help finding a part.
Discussion in '1st Gen. Tacomas (1995-2004)' started by HG88, Feb 11, 2015.
  1. Feb 11, 2015 at 5:18 AM
    HG88
    HG88 [OP] Active Member
    I have a 1997 2.7 4wd. Had to pull my drivers side rear axle. One of the studs that bolts to the axle tube flange was broke and just spinning so I had to cut the nut and stud off. Now I can't find those studs. To be clear I'm talking about the studs that press into the backing plate and bolt the brake backing plate/axle to the axle housing. I'm sure somebody will find them in a tenth of a second but I've yet to find them so any help is appreciated.
  2. Feb 11, 2015 at 10:21 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    These rarely break, so I'd be shocked if a typical autoparts shop carries them. Dealer will have it. I don't think it will cost over $10 for one.
  3. Feb 11, 2015 at 10:44 AM
    HG88
    Yeah I figured they'd be cheap just couldn't find them. I haven't had time to go by the dealership so I was trying to order them.
    I found them here. #42421
    http://www.toyotapartsoverstock.com/showAssembly.aspx?ukey_assembly=490784
    They have LH and RH listed. Wasn't sure if this was referring to left and right hand sides or left or right handed screw thread? I'm pretty sure they were right hand thread.
  4. Feb 11, 2015 at 4:02 PM
    HG88
    Called toyota. They can't even find the dang things.
