Need help finding a rocker switch for fog lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoFMS, Nov 30, 2010.
  1. Nov 30, 2010 at 8:14 AM
    TacoFMS
    TacoFMS [OP] Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build
    Hey im getting ready to mount up some PIAA lights on my bull bar and dont like the switch that comes with the kit. Ive seen a switch out there that is supposedly a factory part but have yet to find out how or where to get/order it from. everyone just says it was around 14 dollars shipped to their door but not how to get it shipped to their door. If anyone has any info on this I would greatly appreciate the help.
    Thanks in advance.
  2. Nov 30, 2010 at 8:18 AM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    i used this switch (toyota part #00550-35976). my local dealer had it in stock. cost me $18 after tax. it's a little steep, but i wanted something oem.
  3. Nov 30, 2010 at 8:41 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
  4. Nov 30, 2010 at 9:30 AM
    warpwr
    warpwr Junior Senior Member
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    DRL mod with switch, rear spring TSB, trans TSB, tailgate mod, snug-top shell.
    This is the switch I used for the DRL mod. Maybe you can use one for fog lights.
    Parts I got from local dealer and www.toyotapart.com , they had pretty good pricing I thought but shipping will bring up the price.
  5. Dec 1, 2010 at 9:18 AM
    TacoFMS
    Justin
    Louisa County, VA
    Hey David, that switch you used. Is that just a simple two wire hookup? just wondering, Im leaning more towards that one. Was wanting something that I dont have to do a lot of splicing and tracking down other wires for. not real fond of cutting into other wires for my truck mainly bc of lack of confidence. also that will fit directly into a knockout that is already in the truck correct?
  6. Dec 1, 2010 at 10:16 AM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    I used the same switch as David and it's nice because it's illuminated when the lights are ON. It's not quite a direct plug-in, you'll need to do a tiny bit of subtle filing. Also, wiring it is pretty easy, although it's got 3 contacts as it needs power to illuminate.
    BTW, this was the OEM switch in my '88 Toyota. While the rounded edges aren't the same as the other current switches, the illumination is worth it to me.
    RZ Rob
  7. Dec 1, 2010 at 10:20 AM
    Di Trut
    Di Trut Well-Known Member
    that cheap factory switch is for the 1st gen tacomas, it doens't match the switches for the 2nd gens. the 2nd gen one is an oem part only right now, and online i remember seeing them for 50-60 bucks.
  8. Dec 1, 2010 at 10:46 AM
    TacoFMS
    Justin
    Louisa County, VA
    ok so I guess the main question i have left is when i get the kit in (PIAA 540 complete kit for the bull bar) will it have 3 wires goin to the switch or does anyone know. also if not if it is only a hot and a relay do i just pick up a ground somewhere else or am i just totally confused?????
  9. Dec 1, 2010 at 10:50 AM
    TacoFMS
    Justin
    Louisa County, VA
    by the way RZRob is that a yorkie wearing a helmet on your name tag??? just wondering if i might need to get my yorkie a helmet too.
  10. Dec 1, 2010 at 10:53 AM
    TacoFMS
    Justin
    Louisa County, VA
    the switches that match the factory 2nd gen that i have seen look like they have pigtail conections on the backs. i dont really know what to do with a pigtail connector and kinda liked the "cheap 1st gen switch" better because of the blade style connection. not to mention that fact taht i kinda dont want it to be the exact same thing as my regular fog light switch. for fear of confusion if my girlfriend or someone else ever gets the truck. i want it to look stock aftermarket if that makes sense??
  11. Dec 1, 2010 at 11:15 AM
    RZRob
    Robert
    Anaheim Hills
    Yes that's one of my wife's Bebe wearing a minature helmet. She doesn't like the helmet, but loves riding on our motorcycles or scooters.
    RZ Rob
  12. Dec 1, 2010 at 2:34 PM
    Di Trut
    check this thread. there are a few different styles of switch that came of fj's that you can use. and there are a few install links in there if you need help wiring.
    http://www.fjcruiserforums.com/foru...discounted-oem-aux-offroad-switch-setups.html
  13. Dec 1, 2010 at 2:54 PM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    Justin, yep basically a two wire hookup (power coming in on one prong, power going out on the other). the third prong goes to ground (i.e. the truck frame) and that makes the led status light turn on when the switch is in the "on" position.
    lemme know if you have any other questions!
