Need help finding metric fitting....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pster, Feb 1, 2009.
  1. Feb 1, 2009 at 12:38 PM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    I am having a devil of a time finding a M12 x 1.25 male/female elbow fitting (preferably brass). Does anyone know of a web site that sells metric fittings like this?
  2. Feb 1, 2009 at 1:04 PM
    HighPlains
    HighPlains Well-Known Member
    Hmmm, a metric pipe fitting. That one is going to be hard to find. The correct term for what I think you are looking is a street elbow.
  3. Feb 1, 2009 at 1:08 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    What the hell are you trying to fix????
  4. Feb 1, 2009 at 1:29 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I am trying to attach my new Fumoto oil drain valve to a 90 degree female/male street elbow fitting so the valve won't stick straight down from my oil pan.
  5. Feb 1, 2009 at 1:37 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I have a 1/4" x 1/4" street elbow male/female. The 1/4" is close to the 12MM, but not close enough for me to screw it into my oil pan. If I can find the 12MM, it will work perfect and substantially reduce the length of the valve protruding from bottom of the oil pan. This will be perfect but I can't seem to find this metric fitting - every fitting in the world you can imagine excpet THIS ONE seems to be manufactured.
  6. Feb 1, 2009 at 1:43 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
  7. Feb 1, 2009 at 10:53 PM
    HighPlains
    12mm is going to be much closer to 1/2 in than 1/4. Either way, neither one will fit right. Will you really be gaining that much clearance anyway? That street elbow is going to extend down probably almost as much as just the valve by itself. Of course, I have not seen the valve.
  8. Feb 2, 2009 at 4:24 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
  9. Feb 2, 2009 at 4:31 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Seems like the interwebs should have something out there...
  10. Feb 2, 2009 at 5:16 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
  11. Feb 2, 2009 at 6:00 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The elbow is gonna put the entire setup down just as far as if you screwed in the fumoto by itself.
    But - if you must.... try McMaster Carr.
    They have everything
    http://www.mcmaster.com/#
    If you can't find it, chances are..it doesn't exist.
  12. Feb 2, 2009 at 8:00 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Janster, nope it won't. I have a 1/4" street elbow and have dry fitted it....cuts 1/2-3/4 inch off the Fumoto extension from the bottom of the pan.....just need to find a metric elbow. Remember, I have the N-Series with the hose nipple which makes it about a 1/2" longer than the older part which did not have the nipple.
  13. Feb 2, 2009 at 8:16 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    That is a machine thread, not a pipe thread. What you are looking for does not exist. All manufactured elbows are pipe threads. If you want one that bad, hit up a local machine shop. They can pop one out real quick.
  14. Feb 2, 2009 at 8:45 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Yep, Metric is European. Can't find it domestically.
  15. Feb 2, 2009 at 8:59 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Its actually the world-wide standard. That type of fitting does not exist period, domestic or international. It is going to be easier to have one made. It will have to be two pieces though.
  16. Feb 2, 2009 at 9:05 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Of course. I meant primarily Euro...and I did in fact find one in the U.K. but too expensive.
