Need help finding OEM metal oil housing cap for 22 TRD off-road tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by stickbug1, Aug 4, 2024.
  1. Aug 4, 2024 at 6:02 PM
    stickbug1
    stickbug1 [OP] Member
  2. Aug 4, 2024 at 7:35 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Yes it will.
  3. Aug 4, 2024 at 8:07 PM
    stickbug1
    Thanks for the reply and also confirming.
  4. Aug 4, 2024 at 8:09 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Any reason you want metal?
    Unless you think something is going to physically break the housing, the metal isn't better.
    The issue is, people think they have to crank the filter housing down TIGHT.
    Not so, the O-ring will NOT seal any better the tighter you get it.
    SNUG is good.....
  5. Aug 5, 2024 at 5:56 AM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    I had a thought once of replacing plastic with metal, but after some research decided to stick with the original. Why? Because hundreds of thousands of Toyotas have no issues using them. Perhaps a few will crack because they are over-tightened or because of a mismatched tool; however in those cases I'd say that the same could occur as well with an aluminum housing.
  6. Aug 5, 2024 at 9:03 AM
    Smudge2075
    Smudge2075 Member
    Matthew
    Florida
    White 2023 TRD Off-road
    Same here. My wife's Corolla had the GRP cap and the only time I ever had an issue is when she would get the oil changed at a quick lube type place and they would torque the crap out of it. Snug it till the lock tab will engage and send it!
    NC Gazzer[QUOTED] likes this.
