need help fj led fog light switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hmsailor, Nov 7, 2020.
  1. Nov 7, 2020 at 7:21 AM
    hmsailor
    hmsailor [OP] Well-Known Member
    Florida
    2015 DCSB 4X4 TRD spORt
    anybody done this mod on their 2nd gen? need help on how to connect the two extra wires (purple and brown) from switch. tia.
  2. Nov 7, 2020 at 10:49 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Going by you diagram.
    Purple looks like it would connect to the dash lights (the ones that come on with the head lights)
    Black looks like a Ground.
    @caribe makaira
  3. Nov 7, 2020 at 10:56 AM
    caribe makaira
    Caribbean, Puerto Rico
  4. Nov 7, 2020 at 12:09 PM
    Muddinfun
    Muddinfun Well-Known Member
    I’d bet my lunch money that a harness made for a FJ Cruiser won’t plug and play with a Taco.
  5. Nov 7, 2020 at 1:10 PM
    caribe makaira
    Snip snip and it will:D
  6. Nov 7, 2020 at 2:28 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Do you have a link for that switch?
  7. Nov 7, 2020 at 4:19 PM
    hmsailor
    Florida
    just use the part number
  8. Nov 7, 2020 at 6:24 PM
    TnShooter
    Deogee
    STOCK
  9. Nov 7, 2020 at 7:25 PM
    caribe makaira
  10. Nov 8, 2020 at 6:38 AM
    hmsailor
    Florida
    i believe some of them have a green or orange back light
  11. Nov 8, 2020 at 7:43 AM
    hmsailor
    Florida
    what about the extra red wire with a ring connector?
  12. Nov 8, 2020 at 11:16 AM
    TnShooter
    Deogee
    STOCK
    The wire looks black to me? The crimp is red. Is this what you are asking about?
    And it looks like it goes back to the switch, the only black wire to the switch is Ground in your diagram.
  13. Nov 8, 2020 at 11:22 AM
    hmsailor
    Florida
    Ok Thanks.
    TnShooter[QUOTED] likes this.
  14. Nov 8, 2020 at 1:02 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Has anyone compared the pinout from the FJ switch to our Gen 2 Tacoma fog light switches? It looks like pin 1/4 and then pin 6 could be showing that the normal panel illumination (6) and the "on" indicator (1 or 4) could be plug-and-play. That would be a nice bit of luck.
  15. Nov 8, 2020 at 1:05 PM
    TnShooter
    Deogee
    STOCK
    The Tacoma uses a 4 pin plug.
    The FJ uses a 6 pin.
    Like @Muddinfun said, they won’t work with each other.
    4xdog[QUOTED] likes this.
  16. Nov 8, 2020 at 1:08 PM
    4xdog
    Santa Fe, NM
    Ah -- I missed that part! Pity... Coulda been so easy. Thanks for the direction.
  17. Nov 8, 2020 at 1:11 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I had an FJ switch on my 2013, worked fine with backlighting tied to my instrument panel and the LED indicator light. It does work.
  18. Nov 8, 2020 at 1:11 PM
    caribe makaira
    De-pin them and they will...
    Mine is been installed since 2005...with LED bulbs for switch illumination.
    TnShooter likes this.
  19. Nov 8, 2020 at 1:27 PM
    TnShooter
    Deogee
    STOCK
    Did you depin as Mike said, or cut and splice?
  20. Nov 8, 2020 at 1:36 PM
    T4RFTMFW
    I did neither, mine didn’t come pre-wired for fogs so I had to start from nothing. Toyota of McDonough used to sell the 2nd gen Tacoma OEM install kit and it came with an FJ switch. Only thing I tapped was for the backlight and LED indicator, IIRC.
    This was in June 2013 or so, so I don’t recall intimate detail. @tacomgee helped me install. We didn’t de-pin or modify the OEM harness.
    At one point I had the whole install documented with pics but that was in a thread that is no longer viewable.
