Need help: flickering lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by IssaGreenTaco, Jul 22, 2022.
  1. Sep 12, 2022 at 1:04 PM
    ridefastflyfar
    ridefastflyfar Well-Known Member
    Tasche
    Hailey, ID
    '02 DCSB, '19 DCSB, '78 FJ40
    That should be enough time!
  2. Sep 12, 2022 at 1:14 PM
    IssaGreenTaco
    IssaGreenTaco [OP] Well-Known Member
    Canton GA
    21 TRD Off-Road
    Dobinsons IMS Lift SPC UCA's
    100%, when i left there it was good and have been good for weeks. Up until last week when it started doing it again but this time more randomly where at the beginning it was consistent. All the time, the lights would flicker with the car off and just opening the door
  3. Sep 12, 2022 at 1:21 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Okay, that may be part of the problem. A circuit can have enough conductivity to show as 'Good' on a DVOM, but still not carry current. The only accurate ways to test the capacity of a ground (or any circuit) are by voltage drop test or by using a test light (best).
    Speedfreak likes this.
  4. Sep 12, 2022 at 2:10 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    The lights are switched on the ground side. So even though they're not on they still have power going to them. While removing it if you touch a ground it can short the module that controls them. Been a few reports of it happening and usually the lights don't turn off after that.
    https://www.tacomaworld.com/threads/dome-lights-wont-turn-off.402358/
  5. Sep 12, 2022 at 2:31 PM
    IssaGreenTaco
    Canton GA
    21 TRD Off-Road
    good information
  6. Sep 12, 2022 at 6:52 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    The flip side to testing a ground for an LED is how small the load is.... the amp draw is so small that a multimeter will test for resistance in the circuit with decent enough accuracy. If load testing though, I like to use a spare high beam bulb across the circuit and then check for voltage drops. Still a good idea though.
  7. Sep 13, 2022 at 4:16 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I'd love to do an LED upgrade for the interior but I'm a coward. I did a Meso Total Tail Stage 1 for the tail lights and it worked perfectly without needing resistors. I'm concerned that if I keep going with the LED swap I will reach a point where the load gets low enough that it drives the canbus system over the edge and causes issues. It may be a totally stupid, unfounded fear but I'll quit while I'm ahead and live with the OEM interior lights. :anonymous:
  8. Sep 19, 2022 at 8:42 AM
    IssaGreenTaco
    Canton GA
    21 TRD Off-Road
    I ended up removing the meso map and dome lights and removed the VLED footwell lights. Install diode dynamics led bulbs in the vanity lights, dome light, map lights, and tag lights. So far (knock on wood) I have not seen any issues happening.
