Need help from a diesel mechanic
Discussion in 'Off-Topic Discussion' started by holyfield19, Feb 2, 2019.
  1. Feb 2, 2019 at 2:25 PM
    holyfield19
    holyfield19 [OP] GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    i have a case 1840 skid steer. It will not start start right now. Turn the key and and it turns over like it had a dead battery and stops. Negative batt cable gets really hot. Like welded to itself hot. New batteries, so I know that's not the problem.
    I believe it is a 4b cummins engine.
    Give me things to check.
  2. Feb 2, 2019 at 2:28 PM
    tcjacado
    tcjacado Well-Known Member
    Is the negative cable securely fastened to the frame. That's one place to start.
  3. Feb 2, 2019 at 2:29 PM
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    It's been cleaned/sanded and checked on both ends.
  4. Feb 2, 2019 at 2:29 PM
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Same with the positive cable.
  5. Feb 2, 2019 at 2:32 PM
    tcjacado
    From what I am reading there is a short somewhere on the positive side. Try this...
    "My suggestion would be to remove the positive cable from the solenoid, and check the resistance from the solenoid terminal to ground. It should be an open circuit (infinite resistance). Check the whole length of the positive cable for cuts in the insulation. Reconnect the battery terminals, and then carefully touch the positive cable back to the solenoid - if it sparks, a short still exists and needs to be found a fixed. "
    snoope and wilcam47 like this.
  6. Mar 29, 2019 at 9:04 AM
    96carboard
    96carboard Well-Known Member
    There are a few possibilities;
    1) If the cable itself has deteriorated inside the insulation, then it will conduct less electricity (causing slow cranking) and get really hot.
    2) Short, as mentioned by @JaCado
    3) Starter motor windings have been overheated and are shorting out, causing excessive current and heat
    4) The engine is not turning as easily as it should be.
    Number 4 is by far the most challenging possibility to address, since it could be caused by any number of problems, including problems with the fuel injection system, big time internal failure, accessory load, etc.
  7. Mar 29, 2019 at 1:16 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Load test the batteries to make sure they're good. Just because they're new...
    Supplement the existing cables with jumper cables; if that makes any change, you know you have a bad cable(s) / connection(s)
    If that's all good, pull & bench test the starter.
    If that's all good... it's probably going to get expensive.
