Need help from people who know carb'd v8's
Discussion in 'General Automotive' started by DSMissed, Feb 24, 2012.
  1. Feb 24, 2012 at 5:30 PM
    DSMissed
    DSMissed [OP] Well-Known Member
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    3" lift with adjustable shocks and AAL, TPS disabled, anytime locker mod, MOOG greasable ball joints and adjustment pins, URD M3 s/c, Pioneer nav headunit, xplod 1000w amp, 10" infinity sub, tinted windows, lightly tinted tails, color matched front grill with blacked out emblem. Do battle scars count as mods?? =D
    This is a 79 Toyota rock crawler that is powered by a 350 with an edelbrock carb. Or.. is not so much powered by it now, since it doesn't run now...
    I drive it every weekend, and it always started kinda hard in cold weather, could be sluggish driving at times acting kinda gutless. I know there was something wrong and I was trying to find the culprit, but I don't know carbs AT ALL, or distributors, points, etc.
    Today it fired and ran a while, then stalled and I've tried 3 hours now and it refuses to run. It will fire a little while the starter is rolling, but it won't actually run by itself. I changed the plugs today, gapped at .45 (thats what the old plugs were) with no change.
    Has an inline fuel filter just before the carb, and there is fuel on either side of the filter, so the carb is definitely getting fuel.
    I think I've narrowed it down tho, I had both carb screws turned out 2 turns, and after cranking a while, the plugs on the passenger side were soaked with fuel, the ones on the drivers side were dry. I did notice a burn mark on one of the plug wires on the ds too. Its an edelbrock 600cfm carb.
    Any ideas or suggestions? I was planning on getting it to a shop, but I can't do that if it isn't running :(
  2. Feb 24, 2012 at 5:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Is the ignition stock?
  3. Feb 24, 2012 at 5:37 PM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    Well... maybe I should take a picture of it.. but the distributor cap is black, I imagine it is stock?
    I didn't build this truck, I actually traded a dirt bike for it, so I don't know much about it.
  4. Feb 24, 2012 at 5:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If the ignition is stock, gap the plugs at .035, and see if that works. Most .045 gaps are for a carbed engine, with a high power ignition, like MSD.
  5. Feb 24, 2012 at 5:40 PM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    MSD would be red, right? Should I take a picture of it to be sure? It ran fine before on the .45 gap, so even if that isn't the correct gap, I don't think thats the problem now..
  6. Feb 24, 2012 at 5:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im starting with the simple things first. I would check the gap. If it runs on the smaller gap, then you have an ignition issue, and can address that.
  7. Feb 24, 2012 at 5:44 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    It's not igniting correctly...??....Don't forget to change the wires too or check for corrosion. Hows the timing?
  8. Feb 24, 2012 at 5:44 PM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    Can I regap and clean the fuel fouled plugs?
  9. Feb 24, 2012 at 5:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would.
  10. Feb 24, 2012 at 5:46 PM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    I have a timing light and intended to use it if I could figure the thing out. But now that it isn't running I don't know how I could check timing? I will be replacing the wires since there is one that is slightly melted from touching a header.
  11. Feb 24, 2012 at 5:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You might also consider taking a peice of fine sand paper (220 grit) to the rotor, and points, and sand off any burn marks.
  12. Feb 24, 2012 at 5:48 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I once had an older model truck that ran funny like this, she was very selective about her timing.
    I have a bad habit of over thinking things so I try to always start with the basics.
    You need Fuel, and fire.
    Gap your plugs as Chris recommended, then check to see if you are getting good even spray out of the jets on the carb.
  13. Feb 24, 2012 at 5:48 PM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    Ok. Lol, no offense, but I read your sig and I'm losing hope that the plug gap will make a difference, since it is so simple lol.
  14. Feb 24, 2012 at 5:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL!!! Yes, but its best to start with the simple things, and work your way into the more tecnical shit.
  15. Feb 24, 2012 at 5:49 PM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    Ok, I am female, so hopefully that will excuse my lack of knowledge, lol. But those are directly under the cap, or do I need to dig deeper to find them? I need a Chilton....
  16. Feb 24, 2012 at 5:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The rotor and points are inside the distributer cap.
  17. Feb 24, 2012 at 5:51 PM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    I have no idea how to check timing when it isn't running, and I also have no idea how to check the jets on the carb. Do I need to take it apart for that? Again... very sorry for the lack of knowledge here... :eek:
  18. Feb 24, 2012 at 5:51 PM
    babytruck
    NorCal
    Don't use being female as an excuse. You can learn and do it just as good as any man. :) It's under the cap.
  19. Feb 24, 2012 at 5:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  20. Feb 24, 2012 at 5:54 PM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    I have to stick up for myself in the sense that I know my small engines and fuel injection... I can tear apart a 4g63 and put it back together and in the car over a weekend... but this carbed v8 stuff is totally new to me, this is my first.
