Need help from the pros!
Discussion in 'Suspension' started by toyo freak, May 30, 2010.
  1. May 30, 2010 at 7:26 AM
    toyo freak
    toyo freak [OP] Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Well I'm looking at Pro comp 3" lift. It says it includes front ex 3000 shocks and rear ex 9000 shocks. What I was wondering is if I could upgrade to their MX6 shocks, how much better would it ride? Or would I better off getting all 4 ex 9000
  2. May 30, 2010 at 7:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    That lift is a spacer lift....Your better off going with a CO, or Old Man Emu set up.
  3. May 30, 2010 at 7:37 AM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
  4. May 30, 2010 at 7:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah...Well...I havent tried that lift, but in my experiance, the Pro comp shocks arent that good of a shock.
  5. May 30, 2010 at 7:39 AM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Alright that means alot coming from you. Thanks
  6. May 30, 2010 at 7:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you plan on keeping the truck for a while, save a little extra dough, and get the OME, Bistien/Eibach, or the like. Also, consider new UCA's to keep the alignment in check. Alot of folks are happy with the 5100's and Eibach springs. The springs are a 1.6" lift, and you can set the billies at .85" to get right at 3" lift (what people are seeing with this set up). And get the 5100's for the rear too, as they are LOADS better than the OEM shocks.
  7. May 30, 2010 at 7:55 AM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Alirght thanks yea benca1 was helping me and told me to do the 5100s at .85 with eibachs and the .75" top plate spacer. Then I should get around 2.5" of lift. Or would I be better off with OME 885 2" coils , 5100s at 0 and the .75" plate spacer. I am looking for around 2.5" of lift and really dont want to replace UCAs
  8. May 30, 2010 at 7:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 885's will give you 2.5 to 3" lift without the top spacers. Same with the Eibachs and billies set at .85". You still may need to swap out UCA's if the truck wanders too much for your taste.
  9. May 30, 2010 at 8:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok. 4x4's may be the exception then....I wouldnt go over 10mmm for a top plate spacer though.
