need help- front bed bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by micah323, Jan 9, 2009.
  1. Jan 9, 2009 at 1:22 PM
    micah323
    micah323 [OP] Well-Known Member
    I purchased a used 06 trd sport about a month ago.
    The bed was missing the front two bed bolts. The back two with the d-rings located by the tailgate were there. So I purchased the two bolts from toyota.
    Went to install them, put them in the hole, and they dont touch anything. Its like a bracket or something is missing.
    Could someone tell what their front bed bolts connect to?
  2. Jan 9, 2009 at 1:28 PM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Maybe some nuts and washers that aren't there. Leave the bolt in the hole and climb under your truck to see whare it's at.
  3. Jan 9, 2009 at 1:31 PM
    micah323
    i can see where it is at just looking throught the fenderwell. The way the bolt is threaded doesnt look like it would use a nut to hold it. Maybe I am wrong. Trying ont to walk up to a strangers truck in a parking lot to peak underneath
  4. Jan 9, 2009 at 1:34 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    :worthless:
    Worth 1000 words. Take some and post so we can figure out what's up.
  5. Jan 9, 2009 at 1:34 PM
    mjp2
    NJ
    Welcome to TW, btw. :)
  6. Jan 9, 2009 at 1:35 PM
    micah323
    ya i willl take some pics. Can any member post pics, or do they need a special membership?
  7. Jan 9, 2009 at 1:38 PM
    mjp2
    NJ
    Pretty sure anybody can. You can even attach it to your post if you go to the "Advanced" screen. Just follow the instructions on the screen. :thumbsup:
  8. Jan 9, 2009 at 1:41 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
  9. Jan 9, 2009 at 2:16 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    The bed bolts bolt right into the frame.
    How did you like paying $12+ for those bed bolts? They must be made of gold or something.
  10. Jan 9, 2009 at 2:56 PM
    micah323
    illl have to look at the bolts and frame again, seemed like they didnt reach.
    ya 12 is a rip. Funny , they tried charging me 41 for both. I went online and found them for $12, so they re looked them up in the comp and had them listed for 12, 17, and 21.
  11. Jan 9, 2009 at 4:05 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Did you notice the bed rattling around when you were driving? My friend had his truck worked on at the dealership and one of the things they did was adjust the bed so it looked straight. Well they straightened it alright , but they forgot to tighten the bed bolt behind the passenger side, even with that bed bolt in, that bed was bouncing up and down on his frame making all kinds of noise.
  12. Jan 9, 2009 at 4:36 PM
    micah323
    bed does not move or rattle at all. the bed mat has the three quarter circles cut out so that the bed bolt holes are visible. I have an after market pace edwards sliding hardtop bed cover that locks. The previous owner put it on. Wonder if they took the bolts out for some reason.
    Ok, I am taking a shot at posting pics of the situation.
    First pic is the bolts with the package showing what should be the correct part number, second pic where the bed mat is cut and u can see the bolts missing.
    Third pic is looking from the fender well at the bolt placed in the hole. You can see it being barely long enough to touch the frame, and lots of threading that is no where near touching anything.
    Thanks for the help guys.
  13. Jan 9, 2009 at 5:14 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Yeah, something is wrong there. It should thread right in. I'm kind of at a loss here...
    FYI: The reason I am familiar with this is because I cross threaded a bolt while installing D rings and had to get a new one. It started threading with probably about 2 inches still until flush.
  14. Jan 9, 2009 at 5:20 PM
    surfsupl
    Gregg
    WestCoast
    This is a picture of my bed bolt threaded into my frame. This is looking straight up from the ground in front of the rear tire.
  15. Jan 9, 2009 at 5:21 PM
    micah323
    could I be missing a whole bracket?
  16. Jan 9, 2009 at 5:22 PM
    surfsupl
    Gregg
    WestCoast
    The picture you show almost looks like the drain hole for water. The bolt that goes to the frame is more towards the front corner of the bed.
  17. Jan 9, 2009 at 5:25 PM
    surfsupl
    Gregg
    WestCoast
    Picture in my bed
  18. Jan 9, 2009 at 5:28 PM
    surfsupl
    Gregg
    WestCoast
    This picture he has posted looks like the drain hole. Looks like the previous owner may have intaled d-rings to prevent the mat from being installed?
  19. Jan 9, 2009 at 5:52 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Yeah, that's not the bolt hole. It should be further back, more towards the tailgate. That looks more like a hole the previous owner drilled. Look at the rough edges.
  20. Jan 9, 2009 at 6:56 PM
    Drew793
    Drew793 Well-Known Member
    New Jersey
    08 TRD Off-Road V6 Auto
    Weather Tech window shades, Roll-N-Lock cover with cargo manager, Led interior bed lights, EZ down tailgate strut, SpiderTrax1.25" wheel spacers, tinted windows, second filter removed, Grillcraft Mesh upper and lower grill, Castrol Syntec.
    I have a Roll-N-Lock retractable bed cover. I drilled two holes in that same location to accomodate the drain tubes from the carrier that holds the cover. For when it rains or any water gets in the carrier.
