Need help! Gasket/coolant
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jerimiahcontreras, Aug 8, 2019.
  1. Aug 9, 2019 at 5:42 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Drilled down to the 4.0.
    Three thickness options.
    https://www.cometic.com/ag-1856950.1856958.1857153-import-auto-toyota-1gr-fe-4-0l-v6-2002-2013.html
    ________________________
    https://www.tacomaworld.com/threads/cylinder-head-gasket-replacement-v6.257035/
    https://www.tacomaworld.com/threads/08-tacoma-4-0l-v6-head-gasket-replcement-question.229222/
    http://www.customtacos.com/tech.old/files/05FSM/repair.html
  2. Aug 9, 2019 at 8:14 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Mine lasted about 235k.
  3. Aug 9, 2019 at 9:32 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There are more options available. Just have to give them a ring. :thumbsup:
