Need help getting squared away
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco-96, Aug 21, 2017.
  1. Aug 21, 2017 at 5:57 PM
    Taco-96
    Taco-96 [OP] New Member
    Jonathon
    1996 sr5
    I have a '96 Toyota Tacoma SR5. I recently bought OME Heavy duty leaf springs, shocks and coil springs. After I installed the leaf springs, I wasn't able to place the drive shaft to the rear diff. I currently have the bed off the truck, though I don't know if that makes a difference. What should I do? Do I need to remove a leaf? Do I need axle shims? And also I am using stock shackles
  2. Aug 22, 2017 at 8:28 AM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
  3. Aug 22, 2017 at 9:03 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    96 as I recall requires shorter leaf springs as the early 1st gen mounts were closer together then the later 1st gen. Did you get the proper ones? Reason I ask is looking at the bumpstop on the frame, it looks like the axle is pushed back a few inches. Either that or the leaf springs are on backwards.
    (I have managed to put regular leafs on a 96, while they physically fit, they wont behave as intended as the shackle angle is terrible)
  4. Aug 22, 2017 at 11:46 AM
    cooper4x4
    cooper4x4 Well-Known Member
    Dallas
    02 Tacoma SAS
