need help...good head scratcher!
Discussion in '1st Gen. Tacomas (1995-2004)' started by s2kvtak, Sep 11, 2009.
  1. Sep 11, 2009 at 7:58 AM
    s2kvtak
    s2kvtak [OP] Well-Known Member
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    Grillecraft grill w/ TRD badge, Bilstein 5100s on all 4 corners set at 2.5" and Toytec AAL in the rear. 285/75-17 Interco TRXUS M/T
    well i finally got me an 04 tacoma last monday. truck has 60k miles on it and runs is great. now suddenly im having a starting problem. its very intermittent and i cant seem to find the problem. i have checked all the grounds that i could find for tightness, all were good. the battery is only a few months old from the previous owner, the connection are tight and not corroded. it happened once the other day and i didnt really think anything about it. last night it did it again and again this morning. what happens is ill turn the key and ill get that annoying little click sound like when you forget to turn your lights off and the battery is dead. turn it again and it fires up. now last night i had to do this about 3 times before it would fire up and this morning it was like 5 minutes the suddenly it came back again. the radio works fine while this is happening aas well as the dash lights and the dome lights.
    please someone help me out. ive had some really bad luck with cars here lately, but they have all been high mileage cars. this ones only got 60k on it. help me out.
  2. Sep 11, 2009 at 8:50 AM
    spasur
    spasur Well-Known Member
    New Orleans
    02 PreRunner 4cyl
    my guess is your starter is toast or something like that...sometimes you can fix the problem by replacing the contacts (so I've heard, fact check this...) or the relay that supplies power to the starter motor.
  3. Sep 11, 2009 at 9:04 AM
    smallcandle
    smallcandle The clown has no penis...
    Brian
    South-central Kansas
    02 DC TRD SR5 4X4
    Deck plate mod, Maglite console mount, Husky Liners front and back, Black powder coated OEM rims, BF Goodrich All-Terrain KO's 265/75/16, Grillcraft MX black insert, Hella 500FF mounted behind grill
    I'm no mechanic (and I don't play one on TV), but I also think it sounds like a starter.
  4. Sep 11, 2009 at 9:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Are you SURE the battery is good? Throw a volt meter on it and watch it while someone tries to start the truck.
  5. Sep 11, 2009 at 9:09 AM
    98tacoma27
    Ben
    Not Beech Creek
    I will take "Bad Starter Contacts" for $400 Alex.
  6. Sep 11, 2009 at 9:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Alex, Im going to stick with "Check the battery" for $100.00
  7. Sep 11, 2009 at 9:12 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    ill take "starter about to die" for $500
  8. Sep 11, 2009 at 9:25 AM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    how much does a starter run for one of these? round-about...hard to replace? meaning tricky to get to? ive changed a starter before on an old cadillac that was a b***h to get to.
  9. Sep 11, 2009 at 9:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The Tacoma starter is fairly easy, just a pain due to lack of hand room. Check the battery first to rule that out. THEN, the starter.
  10. Sep 11, 2009 at 9:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    http://www.youtube.com/watch?v=vXGhvoekY44
  11. Sep 11, 2009 at 9:30 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    ^^ yeahhhh buddy
    OP: Keep us updated!
  12. Sep 11, 2009 at 9:31 AM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Most of the time, an auto parts store or a tire shop will test your battery for free. I'd give that a try first.:)
  13. Sep 11, 2009 at 9:38 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    I would clean the terminals on the batt first. Kyles 07 taco, wouldn't start after a day on the trails in PA. and even though the batt terminals did not look bad, we cleaned them and its started and since then we have had no problems.
  14. Sep 11, 2009 at 9:39 AM
    98tacoma27
    Ben
    Not Beech Creek
  15. Sep 11, 2009 at 9:40 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    autozone tests ur battery and starter for free
  16. Sep 11, 2009 at 9:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What is.....The Jepardy theme song...
  17. Sep 11, 2009 at 9:43 AM
    thestrangebrew
    thestrangebrew AlphaPlanner
    Brian
    Dos Palos CA
    TRD 4x4 Rugged Trail Edition
    Black Badges, Black Center Console
    When I clicked the home tab up top, the thread said "need help...good head". It sounded interesting but I have nothing to contribute lol.
  18. Sep 11, 2009 at 9:44 AM
    98tacoma27
    Ben
    Not Beech Creek
    A video daily double!?!?!?!
    Alex, I would like to wagger $1200.
  19. Sep 11, 2009 at 10:55 AM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    well i just got back from autozone where everything checked out fine. battery, alternator, and starter were all within spec. this makes me think that the contacts are going out. would i be better off to just buy their re-man for $100 with a $62 core or try to replace the contacts?
  20. Sep 11, 2009 at 10:56 AM
    spasur
    New Orleans
    02 PreRunner 4cyl
    the contacts will be cheaper
