NEED HELP got a problem
Discussion in '4 Cylinder' started by JimmyIvine, May 11, 2009.
  1. May 11, 2009 at 1:00 PM
    JimmyIvine
    JimmyIvine [OP] Active Member
    Alberta
    2.7 Liter
    3 inch lift
    Hey I just took my 4 cylinder in the woods and it did good... Just about out of the wood I think my clutch went on me.. My truck isn't getting engaged into gear it seems, I would go to put my truck in 1st gear 4x4 and go to take my foot off my clutch and my truck wouldn't excellerate then I tried 2x4 and the same problem with all gears...
    LONG STORY SHORT: I can put my Tacoma in gear, take my foot off the clutch and my truck wont even stall.
    I think its my clutch and it wont stall when i take my foot off because my trucks not being placed in a gear.
    Need all the help I can get!
  2. May 11, 2009 at 1:31 PM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2014 MGM Double Cab
    2016 TRD Suspension upgrade, 1st gen TRD Wheels, 265/75/16 Cooper RTX
    Did you burn the clutch up?
    Another possibility is that the transfer case is stuck in neutral.
  3. May 11, 2009 at 1:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2
  4. May 12, 2009 at 10:06 AM
    JimmyIvine
    Alberta
    2.7 Liter
    3 inch lift
    Thats exactly it... I have no idea what the problem is, Im thinking its my clutch and thats why when I take my foot off the clutch it wont stall because my trucks not being engaged do to my clutch... Im assuming....
    Anymore ideas i could use all the help!
  5. May 12, 2009 at 4:01 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    bump for some more help
  6. May 12, 2009 at 7:23 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    If you're sure your transfer case is not stuck in neutral, it sounds like you toasted your clutch. Were you slipping it a lot when you were playing in the woods?
  7. May 12, 2009 at 8:06 PM
    JimmyIvine
    Alberta
    2.7 Liter
    3 inch lift
    Yea I was slippin my clutch when I was in the mud its was deep sticky stuff so a little more then usual, so my clutch is most likely dried then eh
  8. May 12, 2009 at 8:30 PM
    Raven65
    Camden, SC
    'fraid so. I think you just bought yourself a new clutch. Sorry man.
  9. May 13, 2009 at 4:15 AM
    jrsmokestacks
    jrsmokestacks Well-Known Member
    Northern, IL
    Long Bed
    Stock work truck
    What year is the truck?? How many miles on it?? You would see a ton of smoke coming out the bell housing before completley burning out the clutch. Were you in 4LO when wheeling?
  10. May 13, 2009 at 5:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your not nessesarily gonna see smoke. If he was in the mud, and it was pretty wet, you can burn the clutch and not even know it.....
  11. May 13, 2009 at 6:05 AM
    argm31i
    argm31i Well-Known Member
    Same scenario happened with me once when I was young and dumb and had a Jeep. Never saw smoke or anything. New clutch was it.
  12. Oct 18, 2009 at 8:56 PM
    JimmyIvine
    Alberta
    2.7 Liter
    3 inch lift
    And a new clutch it was fellas thanks for all your help! Just put a new clutch in and got my frame all redone too! due to the recall on 96 Tacoma's.
  13. Oct 18, 2009 at 8:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to hear its fixed :)
